Topic: Pots Programming in Processing (Read 639 times) previous topic - next topic
groland
Working on a program with three pots. Pots work fine, getting their values works fine. Dividing values by 4 to get variable values 0-255.
I have a prototype program that works fine using key presses. These key presses set a minRed and maxRed color:
if(key == 'a') {
minRed = 0;
maxRed= 60;
which is later used to choose a randomized red color in that range as in:
redValue = int (random (minRed, maxRed));
This all works great.
I want to do the same thing but with pots rather than key presses. When I use the pots, I know I am getting continuously changing values from the sensor, so it doesn't act like a one-time act, like a key press.
Is there a way to take in the sensors' values and treat them as though they were key presses--some way to filter the sensor output to act like a switch?
Thanks,
George
PaulS
Quote
How does Processing decide when to tell the Arduino of a change in value?
Implement that same logic on the Arduino to read the pot values.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
