Topic: Led sensor (Read 558 times) previous topic - next topic
eaj
I have an application that I want to read an IR sensor connected to A0. I would also like to power an IR LED from PIN 13. The problems are:
For the PIN 13 I don't want the full 5v output. Is there a way with programming to give a 2.2v level?
For A0 I want to be able to adjust the threshold to control PIN 3 to go high when the threshold is met.
Any examples of code that may help?
Thanks!
AWOL
Quote
No, but you could use a simple voltage divider, but it sounds more like you just need a simple current-limiter. Can you explain why you think you need a 2.2V level?
Quote
Code: [Select]
digitalWrite (3, analogRead(A0) >= myThreshold);
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
eaj
The IR LED is 2.2V. But you suggest I do this in hardware?
Thanks! I'll try this!! :)
AWOL
Quote
The usual way, with a current-limiting resistor.
Assume 20mA, so
5 - 2.2 / 0.02 = 140 ohm
Go for a 150 ohm, or to be really safe, a 220ohm.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
