Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Live 3D printing  (Read 1494 times)
Copenhagen, Denmark
Offline Offline
God Member
Have you testrun your PDE file today?
View Profile
Drat - missed this post again. Well, now it is on "Notify" ...
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
Got the upgrades installed!
Hard to see, but the arduino mega is hiding down there smiley
Logged
captain-slow.dk | non contagious!
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
Printing again, this time I am attempting to make a Herringbone gear set, and push my printer's accuracy with a layer height of only 0.15mm!
Logged
Netherlands
Offline Offline
Sr. Member
View Profile
I really like the upgrades you do to your machine. They are a great improvement to the original. I would love to have such a machine, but at the moment I don't have the space for it.
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
Printing again... This time I will try to print a sensor bumper for my WiFi Tank 2.0, but the print is tricky... It is long and thin, I am doing a 0.15mm layer height, there are two 45 degree over hangs, and in those overhang there are a hole for an IR proximity sensor... This will not be easy, but I hope it will work smiley-grin
http://www.ustream.tv/channel/blddk-reprap
Logged
Copenhagen, Denmark
Offline Offline
God Member
View Profile
Looks good so far... (yes, finally, seeing it) ... the overhang looks good, too. Did you "just" use the standard converter otr have you manually tweaked the Gcode to better cope with overhang?
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
I am not going to manually tweak the gcode smiley-razz
For this bumper it is a 5.068 megabyte text file, with 134950 lines of code...
But the latest upgrades to my printer changed everything, prints are so accurate, no backlash or anything, and retract on the filament also works because of the gear I printed myself.
And here is the result...
Ping sensor in the front, and IR proximity sensors on each side on a 45 degree angle
And mounted smiley-grin
« Last Edit: August 14, 2011, 01:41:50 pm by bld » Logged
France
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Where did you get the kit from, and for how much?
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
What kit? the rover or printer? The printer is made out of multiple things, and is not from one complete kit.
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Did you only print out a bumper (not the entire chassis)? BTW, the black and white hugging/kissing figurines are cute.
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
Yes, I only printed the bumper
The rest is one like this http://www.ebay.co.uk/itm/New-Arduino-robot-platform-All-Wheel-Drive-4WD-Chassis-/150669950203?pt=LH_DefaultDomain_0&hash=item2314a0fcfb
Logged
CO, USA
Offline Offline
God Member
View Profile
Just explained to my nine year old daughter what "that thing I'm watching" is, I'm pretty sure she will now be insisting that I build a 3D printer to fabricate toys for her on demand.  Hmm.  Not quite that easy, but I like the sentiment....
Don't show her this:
http://singularityhub.com/2011/10/12/origos-3d-printer-could-be-the-last-toy-your-ten-year-old-will-ever-need/
Or maybe do? I'm uncertain of the wisdom of letting a child make their own toys. Certainly, both up- and down-sides to that.
Logged
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
Printing again. smiley
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
I'm curious - what do you use for part designing to print on your reprap? Was there a large learning curve (for part design)?
I've thought about at some point getting a set of printed components and assembling my own printer (I've also given thought to a RepStrap); right now I don't have the time, space, or need, though. Part of my reluctance, though, is the "learning curve" for designing 3D parts - I'm not sure whether I want or need to take such a step yet, but your designs and such (especially the cat feeder) make me see that it might be worth it, even if it takes some time.
smiley
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
smiley
I am using Autodesk Inventor, but that is because I also used it during my education and also a bit at work, so it was something I already knew.
There are many other options out there though, the one most reprappers use, is openscad, but it is code based, where you write everything, and it got a pretty steep learning curve.
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
