Erlangen, Germany
Offline
Jr. Member
« on: July 21, 2011, 09:17:35 am » |
Hi there, our current project is a k-meter, a device to measure the attenuation of light in the water column (which is a core question in fotobiology, biological ozeanography, ecology, etc.). The final version is supposed to have a visible light sensor and separate UV-A and UV-B channels as well as temperature, salinity and depth measurement, a hardware clock and a µSD-Card for data storage. And it is all based on Arduino of course, right now we plan with a MiniArduino but plan to have a small sized Arduino clone with USB on a circlular 60 mm diameter PCB (so you might use it for a cansat ;-)) So far I managed to implement data storage on µSD, hardware clock (DS1307), visible light sensor and temperature (DS18S20). Right now I am about to include the MS5541 depth sensor, which will be hooked onto the SPI-Bus (where already sits the µSD; I ordered the 74HTC1G125 as indicated in the datasheet of the sensor in order to connect it to a shared SPI-Bus). I searched deeply but did not find anything I could use right away (and I am not so much of a programer, if I musn't). Of course I already have all the datasheets and the information to start putting a code together (if I'd knew how to do it quick'n'easy), but does anybody by chance have a working code to read the sensor data? Unfortunately most topics I found in the internet seize without a final documentation and I did not recieve answers on my eMails. I already wondered if it would be a good idea to adapt a code for one of the other SPI-using MS**** sensors, any comments about that? We deeply appreciate the Arduino community which already helped us a lot in building (and dreaming about) other small equipment for our scientific work. If anybody is interested in joining that project of ours, you are welcome! Thank you all very much for sharing great and inspiring ideas and helping most selflessly people who otherwise would propably not dare to start building cool stuff! Greetings from Patagonia Sebastian http://www.efpu.org.ar
Logged
Δεν ελπίζω τίποτα. Δε φοβούμαι τίποτα. Είμαι λέφτερος.
Netherlands
Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
« Reply #1 on: July 21, 2011, 12:26:13 pm » |
Hi Sebastian, Welcome to Arduino forum, sounds like a very interesting abnd valuable project. Have you seen this project @ lady ada: - http://www.ladyada.net/make/logshield/lighttemp.html - I recalled it when I read your story. I already wondered if it would be a good idea to adapt a code for one of the other SPI-using MS**** sensors, any comments about that? You must compare the datasheets, if they look alike, it gives you a good starting point, if they don't you better start from scratch. I don't have a library for the sensor you named, but if you build it and want a code review, you can post it here. Be aware that every SPI device has its own select line and you can have only one SPI device active at the same time. Give this enough attention as you would not be the first with SPI interference caused by this. If you like a review of your code you build so far feel free to post it. Regards from the Netherlands.. Rob How is the weather in Patagonia?
Logged
Erlangen, Germany
Offline
Jr. Member
« Reply #2 on: July 22, 2011, 08:21:57 am » |
Hi Rob, thanks for your quick answer! Bedankt! Yes, in deed I know that project and I think I even used the code for learning the logging procedure. The setup is a little to rough for our kind of radiation measurement, but it is a great project to learn from it. Thanks for the advice with the SPI-Bus; I am thinking in making a string of all the data first and then writing it to the card so every slave would be adressed exclusively. As soon as I have something post-worthy I'll do, and I also hope to provide a good documentation one day if it works neatly. Regards and saludos Seb PS: Weather is fine, a little cold at night, but not so much ashes any more from Puyehue volcano. You can check our weather station on the webpage below (and fotos of the beautiful place).
Logged
Erlangen, Germany
Offline
Jr. Member
« Reply #3 on: August 02, 2011, 01:59:23 pm » |
Uuh, swell! With all the software challenges I did not care for hardware restrictions. Now I got about 21kB to squeeze into the Mini's memory... even without the sensor comunication. Did anybody ever change the 168 for a 328 on an Arduino Mini board and it worked? I do have a USBtinyISP and spare chips, so the bootloader might not be the problem. I only find that it is "irreplaceable", well, how irreplaceable exactly? Thanks Sebastian
_ _ _ UPDATE _ _ _ Irreplaceable my ...! HA! It IS possible to change the chip! OK, it is not a walk in the park, but it is definitely possible: I cut of the chip, because I didn't want to temper with the other components by heating the entire circuit board up. I used my swiss army knife after rejecting the idea do dremel it of - there are lots of vias under the chip, so I think it is safer to cut the pins. Then I cleaned the pads from the pin rests and checked for connections between the pads and also if the pads still were connected to the outbreak pins. Soldering the new chip onto it was quite challenging. Started with a corner pin, then adjusted neatly and attached the opposite corner. Then one pin by one, using a desktop lamp and a magnifying lens to see when the tin got liquid and sucked under the pins. Next time I use one of our stereo microscopes for that. Anyway, afterwards I checked again for shortcuts and corrected. Then I burned the bootloader with my USBtinyISP. And then I used my Duemilanove to upload sketches; this worked with "Duemila or Nano w/ ATmega 328" selected as board, not with the "Mini with ATmega 328". Happy happy, joy joy! Some additional remarks: - I didn't use extra tin but only the rest on the pads. I do not have SMD soldering paste yet. - I know there is a Mini with a 328 available, but I have no possibility to get one here (within a week or two. Besides: everybody could buy one :-) ). OK; the basic problem remains, though, but we will try something about it next week.
« Last Edit: August 03, 2011, 04:30:16 pm by godo »
Logged
Erlangen, Germany
Offline
Jr. Member
« Reply #4 on: August 05, 2011, 06:32:19 pm » |
Hi, today I tried some code I put together: /* MS5541 Pressure Sensor Display Circuit: MS5541 sensor attached to pins 10 - 13: MOSI: pin 11 MISO: pin 12 SCK: pin 13
// library: #include <SPI.h>
//Sensor memory register addresses: const int PRESSURE = 0x0F; //MSB pressure const int PRESSURE_LSB = 0x40; //LSB of pressure const int TEMPERATURE = 0x0F; //MSB temperature const int TEMPERATURE_LSB = 0x20; //LSB temperature const int W1M = 0x1D; // MSB Calibration word 1 const int W1L = 0x50; // LSB Calibration word 1 const int W2M = 0x1D; // MSB Calibration word 2 const int W2L = 0x60; // LSB Calibration word 2 const int W3M = 0x1D; // MSB Calibration word 3 const int W3L = 0x90; // LSB Calibration word 3 const int W4M = 0x1D; // MSB Calibration word 4 const int W4L = 0xA0; // LSB Calibration word 4 const byte RST1 = 0x15; //Reset sequence word 1 const byte RST2 = 0x55; //Reset sequence word 2 const byte RST3 = 0x40; //Reset sequence word 3
// CS just in case const int chipSelectPin = 10;
void setup() { Serial.begin(9600); SPI.begin(); pinMode(chipSelectPin, OUTPUT); delay(100); }
void loop() { //RESET SPI.setDataMode(1); SPI.transfer(0x15); SPI.transfer(0x55); SPI.transfer(0x40); delay(100); //Calibration word 1 unsigned int result1 = 0; unsigned int inbyte1 = 0; digitalWrite (chipSelectPin, LOW); SPI.transfer(0x1D); SPI.transfer(0x50); SPI.setDataMode(0); result1 = SPI.transfer(0x00); result1 = result1 <<8; inbyte1 = SPI.transfer(0x00); result1 = result1 | inbyte1; digitalWrite(chipSelectPin, HIGH); Serial.print("Calibration word 1 ="); Serial.println(result1); //Calibration word 2 unsigned int result2 = 0; byte inbyte2 = 0; digitalWrite (chipSelectPin, LOW); SPI.setDataMode(1); SPI.transfer(0x1D); SPI.transfer(0x60); SPI.setDataMode(0); result2 = SPI.transfer(0x00); result2 = result2 <<8; inbyte2 = SPI.transfer(0x00); result2 = result2 | inbyte2; digitalWrite(chipSelectPin, HIGH); Serial.print("Calibration word 2 ="); Serial.println(result2); //Calibration word 3 unsigned int result3 = 0; byte inbyte3 = 0; digitalWrite (chipSelectPin, LOW); SPI.setDataMode(1); SPI.transfer(0x1D); SPI.transfer(0x90); SPI.setDataMode(0); result3 = SPI.transfer(0x00); result3 = result3 <<8; inbyte3 = SPI.transfer(0x00); result3 = result3 | inbyte3; digitalWrite(chipSelectPin, HIGH); Serial.print("Calibration word 3 ="); Serial.println(result3); //Calibration word 4 unsigned int result4 = 0; byte inbyte4 = 0; digitalWrite (chipSelectPin, LOW); SPI.setDataMode(1); SPI.transfer(0x1D); SPI.transfer(0xA0); SPI.setDataMode(0); result4 = SPI.transfer(0x00); result4 = result4 <<8; inbyte4 = SPI.transfer(0x00); result4 = result4 | inbyte4; digitalWrite(chipSelectPin, HIGH); Serial.print("Calibration word 4 ="); Serial.println(result4); //Temperature: unsigned int tempMSB = 0; byte tempLSB =0; digitalWrite (chipSelectPin, LOW); SPI.setDataMode(1); SPI.transfer(0x0F); SPI.transfer(0x20); delay(30); SPI.setDataMode(0); tempMSB = SPI.transfer(0x00); tempMSB = tempMSB <<8; tempLSB = SPI.transfer(0x00); tempMSB = tempMSB | tempLSB; digitalWrite(chipSelectPin, HIGH); Serial.print("Temperature raw ="); Serial.println(tempMSB); //Pressure: unsigned int presMSB = 0; byte presLSB =0; digitalWrite (chipSelectPin, LOW); SPI.setDataMode(1); SPI.transfer(0x0F); SPI.transfer(0x40); delay(30); SPI.setDataMode(0); presMSB = SPI.transfer(0x00); presMSB = presMSB <<8; presLSB = SPI.transfer(0x00); presMSB = presMSB | presLSB; digitalWrite(chipSelectPin, HIGH); Serial.print("Pressure raw ="); Serial.println(presMSB); delay(10000); } First it looked quite good, then I extracted the calibration factors (5422, 2908, 702, 366, 1202, and 27) from the calibration words (43378, 55058, 44978, and 46875) and I am pretty far away from the usual values in the datasheet. But who cares taking in account that the pressure and temperature reading is overflowing (both 65535)? I am pretty sure my wiring is ok; the OSC signal is quite low (~0,2V), is that ok? I get it from pin 2 of a DS1307. Shall I better generate a signal with an I/O-pin? The 47µF Tn cap is not very close to the pins (~5 cm). Thanks in advance, nice weekend to all! PS: SPI.setDataMode is not really doing anything. Doesn't matter if it is there or not or the other way 'round. PPS: Tried another sensor. Different values, but in the same range. Obviously my code does not work. The workflow for the temp and pressure values is wrong, but I don't know how to do this: Two additional clocks at SCLK are required after the acknowledge signal. Then SCLK is to be held low by the microcontroller until a high to low transition on DOUT indicates the end of the conversion.
« Last Edit: August 06, 2011, 01:33:46 pm by godo »
Logged
Erlangen, Germany
Offline
Jr. Member
« Reply #5 on: August 06, 2011, 02:08:18 pm » |
Hi all, as you see, it is really somehow work in progress... I implemented a clock generated as described here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1271194241. Basically I inserted const int clock = 9; ... pinMode(clock, OUTPUT);
and TCCR1B = (TCCR1B & 0xF8) | 1 ; analogWrite (clock, 128) ;
Now I have a beautiful clock signal and if I am asking for the values I get everything as befor except the temperature reading, which now changes between 65535 and 32767. OK then, what now? Nice weekend to all of you!
Logged
Erlangen, Germany
Offline
Jr. Member
« Reply #6 on: August 12, 2011, 01:37:42 pm » |
Hi, here is a new version of the code. /* MS5541 Pressure Sensor Display Circuit: MS5541 sensor attached to pins 10 - 13: MOSI: pin 11 MISO: pin 12 SCK: pin 13 MCLK: pin 9 Voltage divider converts 5V to 3.3V on all lines except MISO created 4 August 2011 by SMStrauch */
// MCKL signal pin const int clock = 9;
void setup() { Serial.begin(9600); SPI.begin(); SPI.setBitOrder(MSBFIRST); SPI.setClockDivider(SPI_CLOCK_DIV32); //divide 16 MHz to communicate on 500 kHz pinMode(clock, OUTPUT); delay(100); }
void loop() { TCCR1B = (TCCR1B & 0xF8) | 1 ; //generates the MCKL signal analogWrite (clock, 128) ; //RESET SPI.setDataMode(SPI_MODE0); SPI.transfer(0x15); SPI.transfer(0x55); SPI.transfer(0x40); delay(100);
//Calibration word 1 unsigned int result1 = 0; unsigned int inbyte1 = 0; SPI.transfer(0x1D); SPI.transfer(0x50); SPI.setDataMode(SPI_MODE1); result1 = SPI.transfer(0x00); result1 = result1 << 8; inbyte1 = SPI.transfer(0x00); result1 = result1 | inbyte1; Serial.print("Calibration word 1 ="); Serial.println(result1); //RESET SPI.setDataMode(SPI_MODE0); SPI.transfer(0x15); SPI.transfer(0x55); SPI.transfer(0x40); //Calibration word 2 unsigned int result2 = 0; byte inbyte2 = 0; SPI.transfer(0x1D); SPI.transfer(0x60); SPI.setDataMode(SPI_MODE1); result2 = SPI.transfer(0x00); result2 = result2 <<8; inbyte2 = SPI.transfer(0x00); result2 = result2 | inbyte2; Serial.print("Calibration word 2 ="); Serial.println(result2); //RESET SPI.setDataMode(SPI_MODE0); SPI.transfer(0x15); SPI.transfer(0x55); SPI.transfer(0x40); //Calibration word 3 unsigned int result3 = 0; byte inbyte3 = 0; SPI.transfer(0x1D); SPI.transfer(0x90); SPI.setDataMode(SPI_MODE1); result3 = SPI.transfer(0x00); result3 = result3 <<8; inbyte3 = SPI.transfer(0x00); result3 = result3 | inbyte3; Serial.print("Calibration word 3 ="); Serial.println(result3);
//RESET SPI.setDataMode(SPI_MODE0); SPI.transfer(0x15); SPI.transfer(0x55); SPI.transfer(0x40); //Calibration word 4 unsigned int result4 = 0; byte inbyte4 = 0; SPI.transfer(0x1D); SPI.transfer(0xA0); SPI.setDataMode(SPI_MODE1); result4 = SPI.transfer(0x00); result4 = result4 <<8; inbyte4 = SPI.transfer(0x00); result4 = result4 | inbyte4; Serial.print("Calibration word 4 ="); Serial.println(result4); unsigned int c1 = 0; unsigned int c2 = 0; unsigned int c3 = 0; unsigned int c4 = 0; unsigned int c5 = 0; unsigned int c6 = 0;
c1 = result1 >> 3 & 0x1FFF; c2 = ((result1 & 0x7) << 10) | ((result2 >> 6) & 0x3FF); c3 = (result3 >> 6) & 0x3FF; c5 = ((result2 & 0x3F) << 6) | (result3 & 0x3F); c4 = (result4 >> 7) & 0x7FF; c6 = result4 & 0x7F;
Serial.println(c1); Serial.println(c2); Serial.println(c3); Serial.println(c4); Serial.println(c5); Serial.println(c6); //RESET SPI.setDataMode(SPI_MODE0); SPI.transfer(0x15); SPI.transfer(0x55); SPI.transfer(0x40); //Temperature: unsigned int tempMSB = 0; unsigned int tempLSB = 0; SPI.transfer(0x0F); SPI.transfer(0x20); /*int ready = digitalRead (12); while (ready = 0) { delay (10); }*/ delay(50); SPI.setDataMode(SPI_MODE1); tempMSB = SPI.transfer(0x00); tempMSB = tempMSB << 8; tempLSB = SPI.transfer(0x00); tempMSB = tempMSB | tempLSB; Serial.print("Temperature raw ="); Serial.println(tempMSB); //RESET SPI.setDataMode(SPI_MODE0); SPI.transfer(0x15); SPI.transfer(0x55); SPI.transfer(0x40); //Pressure: unsigned int presMSB = 0; unsigned int presLSB =0; SPI.transfer(0x0F); SPI.transfer(0x40); delay(50); SPI.setDataMode(SPI_MODE1); presMSB = SPI.transfer(0x00); presMSB = presMSB << 8; presLSB = SPI.transfer(0x00); presMSB = presMSB | presLSB; Serial.print("Pressure raw ="); Serial.println(presMSB); delay(10000); }
I threw out all the ballast like chip select and Set.Data.Set since it did not make a real difference. Of course, with a couple of loops it will be leaner in the last version. In the //temperature paragraph I tried a while-loop to wait until the sensor indicates end of data conversion by pulling the Dout line down, but I still get all 1s. In the meantime I can not completely rule out any more that the sensor is working properly, although I connected a spare one and the values differ in strangeness a little, but are neither really better nor worse. As a programing noob I really would appreciate every advice I can get. One doubt I have about the reset command is if it is really send as a 24bit block or if there are gaps between each byte. I suppose it is put together during compilation so three seperate command lines in the sketch are as good as on sequence of hex numbers in brackets? Thanks very much in advance Have a nice weekend Sebastian PS I measured with my DSO Nano from Seeedstudio but I did not see movement on sckl nor dout, but I am sure I've choosen the wrong settings. What is the speed of the spi communication? In what resolution can I expect to see something? PPS I replaced the code on Monday, 8/15, with a new version since I found myself a couple of errors during the weekend. Calibration values are now well in the expected range. Speed is adapted. Still, the temp and pressure values are 11111111 11111111, so still no satisfaction. Come on, people! A tiny pressure sensor for about 30€ is a fantastic peripheral we really should make accessible for Arduino!
« Last Edit: August 15, 2011, 03:26:35 pm by godo »
Logged
Erlangen, Germany
Offline
Jr. Member
« Reply #7 on: August 16, 2011, 09:15:33 am » |
Hi there, it works - somehow. Here the current version of the code: /* MS5541 Pressure Sensor Display Circuit: MS5541 sensor attached to pins 10 - 13: MOSI: pin 11 MISO: pin 12 SCK: pin 13 MCLK: pin 9 Voltage divider converts 5V to 3.3V on all lines except MISO created 4 August 2011 by SMStrauch based on application note AN510 from www.intersema.ch */
unsigned int c1 = result1 >> 3 & 0x1FFF; unsigned int c2 = ((result1 & 0x7) << 10) | ((result2 >> 6) & 0x3FF); unsigned int c3 = (result3 >> 6) & 0x3FF; unsigned int c5 = ((result2 & 0x3F) << 6) | (result3 & 0x3F); unsigned int c4 = (result4 >> 7) & 0x7FF; unsigned int c6 = result4 & 0x7F;
Serial.println(c1); Serial.println(c2); Serial.println(c3); Serial.println(c4); Serial.println(c5); Serial.println(c6); //RESET SPI.setDataMode(SPI_MODE0); SPI.transfer(0x15); SPI.transfer(0x55); SPI.transfer(0x40); //Temperature: unsigned int tempMSB = 0; unsigned int tempLSB = 0; unsigned int D2 = 0; SPI.transfer(0x0F); SPI.transfer(0x20); delay(50); SPI.setDataMode(SPI_MODE1); tempMSB = SPI.transfer(0x00); tempMSB = tempMSB << 8; tempLSB = SPI.transfer(0x00); D2 = tempMSB | tempLSB; Serial.print("Temperature raw ="); Serial.println(D2); //RESET SPI.setDataMode(SPI_MODE0); SPI.transfer(0x15); SPI.transfer(0x55); SPI.transfer(0x40); //Pressure: unsigned int presMSB = 0; unsigned int presLSB =0; unsigned int D1 = 0; SPI.transfer(0x0F); SPI.transfer(0x40); delay(50); SPI.setDataMode(SPI_MODE1); presMSB = SPI.transfer(0x00); presMSB = presMSB << 8; presLSB = SPI.transfer(0x00); D1 = presMSB | presLSB; Serial.print("Pressure raw ="); Serial.println(D1); //calculation of the real values const long UT1 = (c5 << 3) + 10000; const long dT = D2 - UT1; const long TEMP = 200 + ((dT * (c6 + 100)) >> 11); const long OFF = c2 + (((c4 - 250) * dT) >> 12) + 10000; const long SENS = (c1/2) + (((c3 + 200) * dT) >> 13) + 3000; const long PCOMP = (SENS * (D1 - OFF) >> 12) + 1000; const float TEMPREAL = TEMP/10; Serial.print("Real Temperature in °C="); Serial.println(TEMPREAL); Serial.print("Compensated pressure in mbar ="); Serial.println(PCOMP); //2nd order compensation only for T > 0°C const long dT2 = dT - ((dT >> 7 * dT >> 7) >> 3); const float TEMPCOMP = (200 + (dT2*(c6+100) >>11))/10; Serial.print("2nd order compensated temperature in °C ="); Serial.println(TEMPCOMP); delay(10000); }
I get this on the serial monitor: Calibration word 1 =21788 Calibration word 2 =35364 Calibration word 3 =24837 Calibration word 4 =28726 2723 4648 388 224 2309 54 Temperature raw =28204 Pressure raw =14665 Real Temperature in °C=17.00 Compensated pressure in mbar =5561 2nd order compensated temperature in °C =17.00
Temperature is fine. Pressure is wrong and increases with every new measurement. Any thoughts? Thank you.
Logged
Netherlands
Offline
Tesla Member
« Reply #8 on: August 16, 2011, 11:21:51 am » |
You really should consider creating functions to reduce memory e.g. reset() Pressure is wrong and increases with every new measurement. Any thoughts? Can you post a sequence of values you got? Is the difference between two consecutive readings (nearly) constant ? Formulas in the code are "quite complex" but I see no reason in the code. Can it be that the sensor does not reset properly?
« Last Edit: August 16, 2011, 11:27:56 am by robtillaart »
Logged
Erlangen, Germany
Offline
Jr. Member
« Reply #9 on: August 16, 2011, 03:25:39 pm » |
Hi Rob, once the code runs well I will make it slim. In the annex is a graph of a 107 s measurement. I think my problem is in the wiring and not so much in the software, what o you think? I touched the sensor to generate some pressure at the point where the values drop. Even so they are quickly stable again, the compensated values climbs up to fall again... I checked the formulas twice today, they are ok. How could I check if the sensor resets? Thanks
Logged
Netherlands
Offline
Tesla Member
« Reply #10 on: August 16, 2011, 05:38:07 pm » |
Found a datasheet at: - http://www.thaieasyelec.net/archives/Manual/MS5541-CM.pdf - 3,3Volt? I checked your code with the datasheet especially the formulas for the 6 correction factors. your code: unsigned int c1 = result1 >> 3 & 0x1FFF; unsigned int c2 = ((result1 & 0x7) << 10) | ((result2 >> 6) & 0x3FF); unsigned int c3 = (result3 >> 6) & 0x3FF; unsigned int c5 = ((result2 & 0x3F) << 6) | (result3 & 0x3F); unsigned int c4 = (result4 >> 7) & 0x7FF; unsigned int c6 = result4 & 0x7F;
If I read the datasheet correctly ( figure Page 12) There is a small diff in c4 (TCO), it need another mask than in your code, but that cannot cause such a problem. c4 is used to calculate the compensated pressure. long c1 = (result1 >> 3) & 0x1FFF; //SENST1 long c2 = ((result1 & 0x0007) << 10) | ((result2 >> 6) & 0x03FF); // OFFT1 long c3 = (result3 >> 6) & 0x03FF; // TCS long c4 = (result4 >> 7) & 0x01FF; // TCO <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< long c5 = (result2 & 0x003F) << 6 | (result 3 & 0x003F); // Tref long c6 = result4 & 0x007F; // TEMPSENS
If I read the formulas correctly the math needs long (32 bits) for intermediate results, so I made the correction factors long so the CPU does the math with enough bits. (Too few bits could cause overflow => strange results) Please give it a try..
Logged
Erlangen, Germany
Offline
Jr. Member
« Reply #11 on: August 16, 2011, 06:41:48 pm » |
OMG, it works! Thanks man, thanks a lot! It seems to have been the "long"-thing, because first I changed the "0x7FF" to "0x1FF" with no effect. But now: joya! Pressing the sensor increased the value nicely, releasing it made it go back to 1007 mbar immediately. OK; now I will try to create a library and some loops to make it a little more neat. Again, thanks a lot!
Logged
Netherlands
Offline
Tesla Member
« Reply #12 on: August 16, 2011, 06:49:50 pm » |
And show us a new graph !!
If you want feedback on the library don't hesitate to ask (don't have such sensor but written/optimized a few small libs)
Logged
Erlangen, Germany
Offline
Jr. Member
« Reply #13 on: August 17, 2011, 11:11:59 am » |
Hi, here is the new graph. You see nicely when I touched and squeezed it and how the temperature rises and slowly falls again.
Logged
Erlangen, Germany
Offline
Jr. Member
« Reply #14 on: August 25, 2011, 12:35:29 pm » |
Hi all, I wrapped up the code and commented it out. To close the case I will post a sketch to read out all calibration words and one which shows how to include the extracted calibration factors into a sketch to avoid reading these constants all the time while using the sensor in whatever application. MS5541_read_all.pde /* MS5541 Pressure Sensor calwords readout This program will read your MS5441 or compatible pressure sensor every 5 seconds and show you the calibration words, the calibration factors, the raw values and the compensated values of temperature and pressure. Once you read out the calibration factors you can define them in the header of any sketch you write for the sensor. Pins: MS5541 sensor attached to pins 10 - 13: MOSI: pin 11 MISO: pin 12 SCK: pin 13 MCLK: pin 9 CS is not in use, but might be pin 10 created August 2011 by SMStrauch based on application note AN510 from www.intersema.ch (http://www.meas-spec.com/downloads/Using_SPI_Protocol_with_Pressure_Sensor_Modules.pdf), and with help of robtillaart and ulrichard. Thanks! */
// include library: #include <SPI.h>
// generate a MCKL signal pin const int clock = 9;
void resetsensor() //this function keeps the sketch a little shorter { SPI.setDataMode(SPI_MODE0); SPI.transfer(0x15); SPI.transfer(0x55); SPI.transfer(0x40); }
void setup() { Serial.begin(9600); SPI.begin(); //see SPI library details on arduino.cc for details SPI.setBitOrder(MSBFIRST); SPI.setClockDivider(SPI_CLOCK_DIV32); //divide 16 MHz to communicate on 500 kHz pinMode(clock, OUTPUT); delay(100); }
resetsensor();//resets the sensor - caution: afterwards mode = SPI_MODE0!
//Calibration word 1 unsigned int result1 = 0; unsigned int inbyte1 = 0; SPI.transfer(0x1D); //send first byte of command to get calibration word 1 SPI.transfer(0x50); //send second byte of command to get calibration word 1 SPI.setDataMode(SPI_MODE1); //change mode in order to listen result1 = SPI.transfer(0x00); //send dummy byte to read first byte of word result1 = result1 << 8; //shift returned byte inbyte1 = SPI.transfer(0x00); //send dummy byte to read second byte of word result1 = result1 | inbyte1; //combine first and second byte of word Serial.print("Calibration word 1 ="); Serial.println(result1);
//Calibration word 2; see comments on calibration word 1 unsigned int result2 = 0; byte inbyte2 = 0; SPI.transfer(0x1D); SPI.transfer(0x60); SPI.setDataMode(SPI_MODE1); result2 = SPI.transfer(0x00); result2 = result2 <<8; inbyte2 = SPI.transfer(0x00); result2 = result2 | inbyte2; Serial.print("Calibration word 2 ="); Serial.println(result2);
//Calibration word 3; see comments on calibration word 1 unsigned int result3 = 0; byte inbyte3 = 0; SPI.transfer(0x1D); SPI.transfer(0x90); SPI.setDataMode(SPI_MODE1); result3 = SPI.transfer(0x00); result3 = result3 <<8; inbyte3 = SPI.transfer(0x00); result3 = result3 | inbyte3; Serial.print("Calibration word 3 ="); Serial.println(result3);
//Calibration word 4; see comments on calibration word 1 unsigned int result4 = 0; byte inbyte4 = 0; SPI.transfer(0x1D); SPI.transfer(0xA0); SPI.setDataMode(SPI_MODE1); result4 = SPI.transfer(0x00); result4 = result4 <<8; inbyte4 = SPI.transfer(0x00); result4 = result4 | inbyte4; Serial.print("Calibration word 4 ="); Serial.println(result4);
//now we do some bitshifting to extract the calibration factors //out of the calibration words; read datasheet AN510 for better understanding long c1 = result1 >> 3 & 0x1FFF; long c2 = ((result1 & 0x07) << 10) | ((result2 >> 6) & 0x03FF); long c3 = (result3 >> 6) & 0x03FF; long c4 = (result4 >> 7) & 0x07FF; long c5 = ((result2 & 0x003F) << 6) | (result3 & 0x003F); long c6 = result4 & 0x007F;
//Temperature: unsigned int tempMSB = 0; //first byte of value unsigned int tempLSB = 0; //last byte of value unsigned int D2 = 0; SPI.transfer(0x0F); //send first byte of command to get temperature value SPI.transfer(0x20); //send second byte of command to get temperature value delay(35); //wait for conversion end SPI.setDataMode(SPI_MODE1); //change mode in order to listen tempMSB = SPI.transfer(0x00); //send dummy byte to read first byte of value tempMSB = tempMSB << 8; //shift first byte tempLSB = SPI.transfer(0x00); //send dummy byte to read second byte of value D2 = tempMSB | tempLSB; //combine first and second byte of value Serial.print("Temperature raw ="); Serial.println(D2); //voilá!
//Pressure: unsigned int presMSB = 0; //first byte of value unsigned int presLSB =0; //last byte of value unsigned int D1 = 0; SPI.transfer(0x0F); //send first byte of command to get pressure value SPI.transfer(0x40); //send second byte of command to get pressure value delay(35); //wait for conversion end SPI.setDataMode(SPI_MODE1); //change mode in order to listen presMSB = SPI.transfer(0x00); //send dummy byte to read first byte of value presMSB = presMSB << 8; //shift first byte presLSB = SPI.transfer(0x00); //send dummy byte to read second byte of value D1 = presMSB | presLSB; //combine first and second byte of value Serial.print("Pressure raw ="); Serial.println(D1);
//calculation of the real values by means of the calibration factors and the maths //in the datasheet. const MUST be long const long UT1 = (c5 << 3) + 10000; const long dT = D2 - UT1; const long TEMP = 200 + ((dT * (c6 + 100)) >> 11); const long OFF = c2 + (((c4 - 250) * dT) >> 12) + 10000; const long SENS = (c1/2) + (((c3 + 200) * dT) >> 13) + 3000; long PCOMP = (SENS * (D1 - OFF) >> 12) + 1000; float TEMPREAL = TEMP/10;
delay(5000); }
PS: Un-voided the resetsensor call as of today, Nov 25 2011.
« Last Edit: November 25, 2011, 03:19:36 pm by godo »
Logged
