Loading...
Pages: [1]   Go Down
Author Topic: Fun, unique sensors for musical toys?  (Read 273 times)
0
Offline Offline
Full Member
View Profile
WWW
I'm putting together a series of about 10 Arduino-based synths, each using different sensors to make noise. I'm curious what other strange, cool sensors you all might be able to suggest for me. The sensors will need to be +5V powered and generate an analog signal between 0-5V (for use with the Analog In pins on the Arduino).
So far, I've come up with the following:
IR rangefinder (long distance) = general motion of visitors used for sound
Temperature sensor = thinking of casting these into small (<2" diamter) balls of ballistics gel, and the visitors have to pick them up and try to warm them to change the pitch
Alcohol gas sensor = your degree of drunk-ness turned into sound
Piezo element = after some AC->DC conversion, should be able turn force into sound (with lots of interesting echos and reverb from the fuzzy vibrational signature)
Flex sensor = will be slipping this into a medical tube, so that the amount of bend of the tube will determine pitch.
Can anyone suggest any other neat (and cheap) sensors?
Logged
Grad student, creative technologist, OSHW engineer
http://jason-webb.info
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Resistive force sensors:
http://www.sparkfun.com/products/9375
Light intensity sensor also resistive:
http://www.sparkfun.com/products/9088
Logged
0
Offline Offline
Full Member
View Profile
WWW
Will definitely order some photocells. How can an FSR be used differently than a simple piezo element? Does it detect sustained pressure?
Logged
Central MN, USA
Offline Offline
Faraday Member
View Profile
WWW
Force or pressure reduces the resistance of the sensor. You will need to make a series circuit of the sensor and a fixed resistor and sense the voltage in the middle. Google voltage divider.
Logged
Netherlands
Online Online
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Quote
Every person is a resistor ... different parts have different resistance ...
Every person is also a capacitor ....
humidity sensor, radioactivity, hall sensor for magnetic fields, a rotary encoder (turning a wheel round fast) ,...
Have a look at the playground, a lot of sensors are mentioned there (including example code !)
my 2 cents,
Rob
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
