Loading...
Pages: [1]   Go Down
Author Topic: Advice on optocoupler  (Read 276 times)
Offline Offline
Newbie
View Profile
Hi
In my project I need to trigger a Fuji disposable flash with my Arduino Uno. I got told to use a optoisolator/optocoupler to prevent damage to the board. The problem is that I do not have access to a lot of products due to my location, but what I have found is this:
http://www.sparkfun.com/datasheets/Components/SMD/ild205t.pdf
Being new to electronics I not 100% sure I know what to look for, but under the "Coupler" heading it looks promising, again not 100% sure what to look for. The flash is said to give off approx. 200V, but lets say 200V to 300V to be safe, differnet websites seem to have different values for the same flash smiley-neutral. The flash would only be triggered once or twice every few minutes. Any other recommendations on what to use?
Thanks for the help!
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
See if you can get hold of a MOC3020 optotriac.
Simple, output isn't polarised, and it is available in a DIP package.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
Thanks for the reply.
Unfortunately not, unless I order out the country. I take it your previous post means that the Sparkfun one i mention is not suitable?
My Multi-meter arrived this morning the Flash gives a reading of 204V so at least I now have a number to work with.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
Not unless you use it to trigger another device like and external triac - the collector-emitter breakdown voltage is much too low for your flash (70V vs. 240V).
See if you can find an opto-triac or opto-thyristor - these are usually designed for much higher voltages than transistors.
Logged
Offline Offline
Newbie
View Profile
Thanks I will do that.  smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
