Topic: transmitter troubles (Read 804 times) previous topic - next topic
jkaps
Hi all,
I am new to circuits so I appreciate any help. I have a 315MHZ transmitter/receiver pair but they are not working correctly. I have a Teensy 2.0 reading the value of analog sticks and then sending that value through the transmitter to and Arduino Nano 3.0. My problem is that the signal being outputted by the transmitter is a lot stronger(higher) than the one being received by the receiver.(I attached my oscilloscope image to help you understand the problem, CH1 is my transmitter and CH2 is the receiver). please give me any ideas you have, at this point ill try anything.
Thanks
CrossRoads
Are you using antennas? Does the receiver have good power?
What are the two modules?
jkaps
1. The antennas are optional, but as I am testing in a six inch area I dont think they are necessary 2. Yes the receiver is getting good power (not the optimal 9v but it is getting 6) 3. I am using this 315MHZ low cost transmitter/receiver pair http://www.robotshop.com/seeedstudio-315mhz-rf-low-cost-transmitter-receiver-pair.html
Thanks for your time
floresta
#3
Jul 21, 2011, 09:47 pm Last Edit: Jul 21, 2011, 10:15 pm by floresta Reason: 1
The antennas are optional ...
And the options could very well be
(a) if reliable operation is required then use antennas.
(b) if reliable operation is not required then don't use antennas.
One wouldn't normally think that antennas are necessary for a 6" range, but you are talking about very inexpensive (cheap) devices.
Don
jkaps
I added the Antennas yet the problem has not gone away.
KE7GKP: Yes it was from the correct data output pin on the receiver, I double checked after your suggestion. I agree that the signal is getting there but it is very low but why?
Thanks
CrossRoads
What is the receive data pin going into? Arduino pin set up as an input & nothing else? The signal looks to be loaded down by something.
jkaps
Yes it is just input to the RX pin on the arduino and then the arduino controls servos based on the signal.
CrossRoads
Post your sketches then, and whatever you have for scheematics, lets see what is going on.
