Loading...
Pages: [1]   Go Down
Author Topic: Microcontroller? We don't need no microcontroller!  (Read 608 times)
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Here's a shot of a digital clock (I think!) or maybe its a 7-digit counter, I don't recall anymore, I found it in a box in the basement while looking for something else.
555 with RC & trim pot for clock source, some 7404/7400/7408 across the bottom
2nd row is 6 74163s and a 74160, so 28 bits of synchronous counter
3rd row, a 74H74 and parts likely cannibalized for something else (they are wired up)
4th row is 7447's driving the digits, which are HP 5082-7730s.
Things that look like burn marks are epoxy, apparently I reused this piece of non-copper clad perfboard.
Back is mix of wirewrap, caps soldered on the sockets after wiring, and point to point soldering for the resisters to the LED leads (be tough to reuse those now!).
Ah, the good old days - parts are dated coded 1978, 1978, so was probably built when I was co-op student after college sophomore year.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Grand Blanc, MI, USA
Online Online
Faraday Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
Cool, I've got something similar I should take some pics of.  Now for the $64K question ... does it still work?
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Not without some effort - add a 5V source, find the hand drawn schematic somewhere and see what else is missing. Its in great shape for being 30 years old tho.
Logged
Toronto, Canada
Offline Offline
Edison Member
"Keep it R.E.I.L. - "Research, Experiment, Investigate and Learn"
View Profile
That look interesting... Can you re-use the parts ?   And are you doing revesed engeneer of this board ?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Sure, the DIP just come out of the sockets. Unsolder the caps from the back of the sockets, clean the pins off, undo the wierwrapping. Have a nice handful of parts to work with. Unfortunately the ICs are mostly 74xxx logic (not LS, not HC, not ACT, but straight 74163) and am pretty sure are power hungry little beasties.
I don't need to reverse engineer, I can go root around in some more boxes and find my 30 year old hand drawn schematic.
Or just design it again from scratch if I really wanted to.
I have other projects I am looking to tackle first, like being able to get boot loadeds on blank uCs and then building up some boards this weekend.
Logged
nr Bundaberg, Australia
Online Online
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
That's fantastic, takes me back.
I wouldn't bother salvaging the chips, each one will draw more power than a modern laptop smiley Mind you they might make good heating elements for a high-altitude ballon project.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Western New York, USA
Offline Offline
Faraday Member
View Profile
Are you guys really going to make me dig out my TTL repeater controller?
Don
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
If you do, I can go find another old project!
Maybe we should have another thread ...
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Suggest starting another thread in bar/sport with "dinosaur turd circuits"  smiley-mr-green
My first self-motivated circuit/electronics project was on an arduino 2009  smiley-wink
Logged
Online Online
Tesla Member
View Profile
WWW
Quote
Yep, maybe under Exhibitions or Bar sport. I'm sure there's a lot of old projects people would display.
______
Rob
Logged
Central MN, USA
Offline Offline
Faraday Member
View Profile
WWW
A good idea. This board is mostly for non-outdated electronics  smiley-wink
Logged
Pages: [1]   Go Up
Print
Jump to:
