Topic: Need to move motor / actuator back and forth remotely via bluetooth (Read 4186 times) previous topic - next topic
notoriousalpha
thanks for the quick responses!
1:how can i measure the draw
2:should i get a slightly smaller relay?
3:the arduino could make the relay click before, now it cant... do these things fry easily?
4:thanks for all the help
notoriousalpha
how do i do that? and can i somehow use a mosfet here?
retrolefty
If it's a 12volt coil relay just wire it across a 12vdc power source and measure the current in series with a meter.
No, just size the switching transistor (max current rating and voltage) well above the current draw of the relay coil.
No, relays don't fry easily. Perhaps you damaged the arduino output pin by drawing too much current to it or somehow wired +12vdc to the output pin?
Your welcome. Just follow closely the arduino relay drawing - http://arduino.cc/playground/uploads/Main/relays.pdf
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
