Topic: Thermocouple amp with MUX on a mega (Read 1 time) previous topic - next topic
VroomVroom
Jul 22, 2011, 05:31 am Last Edit: Jul 22, 2011, 05:37 am by VroomVroom Reason: 1
Hey guys,
Just bought this shield to get a few thermocouples connected to my arduino data logger: http://www.oceancontrols.com.au/KTA-259.html
It has a MAX6675 thermocouple amp on board with a ADG608 mux. Not too used to these devices and a beginner with the arduino so I was relying on the example code (which works ona deumi but not on the mega):
 Ocean Controls k-type board KTA259 TC Mux
 Neil Davey
 06-02-11
#include <SPI.h>
#define CS_TEMP  9 // MAX6674/6675 /CS Line
#define MUX_EN   7 // ADG608 MUX Enable
#define MUX_A0   4 // ADG608 Addr0
#define MUX_A1   5 // ADG608 Arrd1
#define MUX_A2   6 // ADG608 Addr2
void Set_Mux_Channel(unsigned char chan)
 switch(chan)
   // MUX Channel 1
   case 1:
     digitalWrite(MUX_A0,LOW);
     digitalWrite(MUX_A1,LOW);
     digitalWrite(MUX_A2,LOW);
     break;
   // MUX Channel 2
   case 2:
     digitalWrite(MUX_A0,HIGH);
     break;
   // MUX Channel 3
   case 3:
     digitalWrite(MUX_A1,HIGH);
     break;
   // MUX Channel 4
   case 4:
     break;
   // MUX Channel 5
   case 5:
     digitalWrite(MUX_A2,HIGH);
     break;
   // MUX Channel 6
   case 6:
     break;
   // MUX Channel 7
   case 7:
     break;
   // MUX Channel 8
   case 8:
     break;
   default:
     break;
int Read_Temperature(void)
unsigned int temp_reading;
 // force conversion now..
 delay(5);
 digitalWrite(CS_TEMP,LOW); // Set MAX7765 /CS Low
 delay(5);
 digitalWrite(CS_TEMP,HIGH); // Set MAX7765 /CS High
 delay(250); // wait for conversion to finish..
 // read result
 delay(1);
 temp_reading = SPI.transfer(0xff) << 8;
 temp_reading += SPI.transfer(0xff);
 delay(1);
 // check result
 if(bitRead(temp_reading,2) == 1) // No Connection
     return(-1); // Failed / NC Error
     return((int)(temp_reading >> 5)); //Convert to Degc
 pinMode(10,OUTPUT); // Hardware /SS, need to be output
 pinMode(CS_TEMP,OUTPUT); // MAX6675/6674 /CS Line
 pinMode(MUX_EN,OUTPUT); // Enable pin on ADG608
 pinMode(MUX_A0,OUTPUT); // A0 on ADG608
 pinMode(MUX_A1,OUTPUT); // A1 on ADG608
 pinMode(MUX_A2,OUTPUT); // A2 on ADG608
 digitalWrite(MUX_EN,HIGH); // Enable on
 SPI.begin(); // Init SPI
 Set_Mux_Channel(1);
 Read_Temperature();
int temperature = 0;
while(1)
   Set_Mux_Channel(1);
   temperature = Read_Temperature();
   if(temperature == -1)
       Serial.println("N/C");
       Serial.print(temperature,DEC);
       Serial.println(" DegC");
Just wondering how to go about getting this working on an arduino mega that has a sparkfun microsd shield attached. The sd shield uses digital pin 8 as CS. I have enabled software SPI to get the sd shield working on the mega (i.e. not using  digital pins 51-54 but rather 10-13 - like the deumi)
From my research on these forums it appears you can have multiple SPI devices provided you use different CS pins?
Also, I have analog inputs 0 to 9 being used already, is this going to be a problem?
graynomad
#1
Jul 22, 2011, 08:01 am Last Edit: Jul 22, 2011, 08:07 am by Graynomad Reason: 1
I always thought it was not a good idea to run t-couples through a MUX, still if it works it works.
while(1)
    Set_Mux_Channel(1); <<<<<<<<<<<<<< should be a variable, not 1
You never select the other channels. Also you don't need the while(1) but it doesn't do any harm.
That's normally true, but I'm not familiar with the SPI library so don't know how it does the CS stuff.
______
Rob
