Loading...
Pages: 1 [2]   Go Down
Author Topic: Virtual switch  (Read 1040 times)
Los Angeles, CA, United States
Offline Offline
Full Member
View Profile
I should have stated this in the beginning but the flash is a disposable camera flash and the idea is just to make a high speed photography trigger with the parts available at www.allelectronics.com. What parts would I need? I was thinking of using this:
but I cant find a Opto Isolator at All Electronics that works.
Logged
C program run. C program crash. C programmer quit.
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
MOC3020
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Full Member
View Profile
I cant seem to find that at the Allelectronics website.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
http://tinyurl.com/4xdy2ne
Logged
Offline Offline
Full Member
View Profile
I know how to use google. I want to get the optoisolator from All Electronics as it is 5 minutes from where I live.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Maybe they don't stock such useful items, and you'd have to spread your seach a little wider.
Logged
Offline Offline
Full Member
View Profile
What are the specs that I need on the optoisolator for this to work. I will go to all electronics today and compare the selection to the specs and buy a few. All Electronics has the following on there website:
NPN transistor output. 6 pin DIP package.
NPN darlington output. 6 pin DIP package.
Would any of these work?
When I went there previously they had a few more in store than they had online.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Opto triac, or opto-transistor plus external triac or thyristor.
An optotransistor by itself isn't going to work at flash trigger voltages.
Logged
Offline Offline
Full Member
View Profile
By searching that I found a Triac-output, 400V optoisolator. 6-pin DIP package at allelectronics: http://www.allelectronics.com/make-a-store/item/MOC3022/OPTO-ISOLATOR-TRIAC-OUTPUT/1.html
That will work right?
Datasheet here: http://www.alldatasheet.com/datasheet-pdf/pdf/27237/TI/MOC3022.html
« Last Edit: July 24, 2011, 03:49:59 pm by Carnyworld » Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
A MOC3022?
Yes, I think that's close enough to a MOC3020.
There's a very subtle difference, can't remember what is is - maybe the datasheet will make it clear.
Logged
Offline Offline
Full Member
View Profile
I will get it. When I do get it though is there a chance that I could fry my arduino?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Not if you wire it up right.
I use MOC3020s to fire 20-odd year old flashguns, plus some home-brew devices.
One commercial unit has a voltage of around 180V across the terminals.
Another, with the same model number, but about 5 years younger, has about 6V.
Just make sure that all the output terminals of the isolator are connected to is the flash.
Nothing common, hot-side.
« Last Edit: July 24, 2011, 04:10:54 pm by AWOL » Logged
Offline Offline
Full Member
View Profile
Thanks! I will post back here if I run into any problems.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Don't forget to add a current-limiting resistor to the input side.
Logged
Offline Offline
Full Member
View Profile
Got it, Thanks again!
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
