Topic: using a different type of resistor for rotary encoder..... (Read 719 times) previous topic - next topic
D.J.B
in the playground there is a link to using a dc motor as a rotary encoder...
LINK
http://christian.liljedahl.dk/guides/simple-rotary-encoder
... it talks about using a 15K resistor, could i use a different resistor or will it be a big difference??
floresta
Quote
How 'different'  will your new resistor be.  How similar to his motor will yours be?  I'm sure a 12K or 18K will be no better or worse a choice than his 15K.  After all he did specify 10-20K above the picture.  I'm pretty sure that he didn't do any extensive calculations before he came up with that range of values either, it's more likely that he happened to have a 15K resistor handy and it worked with his motor.  I would be suspicious of the technical qualifications of someone who consistently refers to a potentiometer as a potmeter.
Don
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
