Ok, thanks,
I will make a backplane where i can plug the arduinomega, the ethernet board and maybe also a sd fo log,
Just for fun, i put the screenshot of the serial output of my arduino plc program.
You need to use putty in serial usb or com1, with the terminal config option for keyboard
Backspace key = control-h, then you can come back and modify you serial command.
the usbcom and com can be use at the same time ( 2 input buffer )
Arduino PLC
>help
You can type :
di Display input
do Display output
dm Display memory
da Display analog value
dt Display timer
sm x Set the memory x
rm x Reset the memory x
dl Display the loop done by sec
>di
Input
i8 to i1 : 00000000
i16 to i9 : 00000000
i24 to i17 : 00000000
i32 to i25 : 00000000
>do
Output
O8 to O1 : 00000010
O16 to 09 : 00000000
>dm
Memory
M8 to M1 : 00000000
M16 to M9 : 00000000
M24 to M17 : 00000000
M32 to M25 : 00000000
M40 to M33 : 00000000
M48 to M41 : 00000000
M56 to M49 : 00000000
M64 to M57 : 00000000
M72 to M65 : 00000000
M80 to M73 : 00000000
M88 to M81 : 00000000
M96 to M89 : 00000000
M104 to M97 : 00000000
M112 to M105: 00000000
M120 to M113: 00000000
M128 to M121: 00000000
>help
You can type :
di Display input
do Display output
dm Display memory
dt Display timer
>da
Analog value
Ad(0) : 101
Ad(1) : 102
Ad(2) : 102
Ad(3) : 103
Ad(4) : 102
Ad(5) : 103
Ad(6) : 105
Ad(7) : 104
Ad(
: 102
Ad(9) : 102
Ad(10) : 101
Ad(11) : 102
Ad(12) : 102
Ad(13) : 101
Ad(14) : 101
Ad(15) : 99
>dt
Input
ti8 to ti1 : 00000000
ti16 to ti9 : 00000000
Output
t8 to t1 : 00000000
t16 to t9 : 00000000
Timer value
T1 : 0
T2 : 0
T3 : 0
T4 : 0
T5 : 0
T6 : 0
T7 : 0
T8 : 0
T9 : 0
T10 : 0
T11 : 0
T12 : 0
T13 : 0
T14 : 0
T15 : 0
T16 : 0
>help
You can type :
di Display input
do Display output
dm Display memory
dt Display timer
>dl
Loop by sec : 2006
>dl
Loop by sec : 2005
>dm
Memory
M8 to M1 : 00000000
>sm 1
Set memory 1
>dm
Memory
M8 to M1 : 00000001
>rm 1
Reset memory 1
>dm
Memory
M8 to M1 : 00000000
