Topic: Arduino Power: 5V, USBVCC, VIN, VCC30, PWRIN, Huh?!! (Read 3015 times) previous topic - next topic
gknight4
I'm sure this makes sense to you folks, but I'm adrift. What are all these voltages? Why does it compare 1/2 of Vin with VCC30 to determine what to do with USBVCC and +5V? What is the method to what appears to be this madness?
Thanks!
Thumbs Up!
Gene Knight
cmiyc
You might want to add some context to your question.  I'm at a loss to what you are asking.  I'm even more at a loss to understand what the question has to do with installation or troubleshooting.
gknight4
What a great description. Thanks!
I admit, most of this made sense, but you've done a great job of explaining the rest. So, if Vin is less that 2 X VCC30, then  USBVCC is connected to +5V? Otherwise, the power is supplied from the on-board regulator, from Vin. And VCC30 is generated by the USB chip? It makes sense now, but was not obvious to me. Thanks!
Thumbs Up!
Gene Knight
cmiyc
#3
Jul 23, 2011, 05:39 pm Last Edit: Jul 24, 2011, 01:35 am by James C4S Reason: 1
As KE7GKP pointed out, it depends on the type of Arduino.  Older designs used the FTDI chip's internal 3.3V regulator.  Newer boards, such as the UNO, use a dedicated on-board regulator.
