Topic: Arduino question (Read 1 time) previous topic - next topic
Arduino02
Is there a way to send commands to the arduino over a serial connection. I want to be able to control a servo via a serial connection to the computer. My arduino will be here Thursday along with a breadboard wires and a servo. Thank you very much.
johnwasser
You will need to shift the voltage levels because the RS323 serial port uses positive and negative voltages higher than Arduino can accept.  You want 0-to-5V (TTL) signal levels.  Look at the "Single Sided Serial" Arduino design for the basic circuitry.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
