Loading...
Pages: [1]   Go Down
Author Topic: What sensor?  (Read 306 times)
Just past the last tree on the left
Offline Offline
Full Member
Ó Fithcheallaigh
View Profile
Hello,
Hope someone can help.
Is there a sensor I can use to measure a persons skin resistance? I would like to put it on a car steering wheel, as part of a voltage divider circuit, with the skin resistance been the variable.
Thanks in advance.
Seán
Logged
Ná bac le mac an bhacaigh is ní bhacfaidh mac an bhacaigh leat.
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
There would probably be a problem with using skin resistance in a simple voltage divider network as the arduino analog input pin wants to see a driving source impedenance of 10,000 ohms or less, so your measurements are likely to be quite noisy and maybe even useless. Skin resistance is pretty high in most people and also absolute skin resistance of people vary over a wide margin. What is the purpose of this measurement, indication of 'stess' a driver is feeling, or something else?
Lefty
Logged
Offline Offline
Full Member
Ó Fithcheallaigh
View Profile
Thanks for the replies.
Yea, it is to take a look at stress levels of drivers in specific situations.
I was thinkng I would feed the signal through an op-amp to boost the signal so that I can actually work with it.
Seán
Logged
Offline Offline
Full Member
Ó Fithcheallaigh
View Profile
Thanks for that!
Seán
Logged
Pages: [1]   Go Up
Print
Jump to:
