Loading...
Pages: [1]   Go Down
Author Topic: 328P-20PU VS 328P-PU ??  (Read 612 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
hi am i right in thinking the only difference between the 328P-20PU and the 328P-PU is the 20PU is good for 20Mhz? as apposed to the 16Mhz 328P-PU??
basically im looking to buy some pre-loaded (bootloader) atmega chips for a project so i can just plug them into the arduino board flash them with my project and then plug them into the final project, however my chip is a ATMEGA328P-20PU and the chips im looking at buying are ATMEGA328P-PU chips, just wanted to check that they are compatible before i buy them.
thanks guys, apologies if this is in the wrong section.
kris
Logged
Humboldt, CA
Offline Offline
Full Member
Arduino BBB
View Profile
Shouldn't make any difference at all.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
thank you, just wanted to make sure smiley-grin
Logged
Offline Offline
God Member
Arduino rocks
View Profile
Different suppliers may pick a different name (sometimes even incorrect or misleading) for their product listing.
As far as I know there is no 16MHz DIP version of the AtMega328 as all DIP versions are rated for 20 MHz (there is an automotive version rated for 16 MHz max, but they do not come as –PU versions). The bootloader will require/expect a specific frequency and so you need to verify that this match your requirements.
As for 328P-PU versus 328P-20PU I think it is safe to assume they’re not only compatible, but identical.
Logged
Pages: [1]   Go Up
Print
Jump to:
