Topic: Loop Back Test - Sticky? (Read 82975 times) previous topic - next topic
0xSAM
Good write up... thanks for the details
jrpjim
New to Arduino and programming first time user so the direction
6. Start your favourite terminal application.  Serial Monitor will work fine.
does not tell me what I should do as I do not have a favourite Terminal application and don't know what Serial Monitor is.
Coding Badly
I am sorry to hear you are struggling with Google.  This should help...
https://www.google.com/search?q=arduino+serial+monitor
Mocivnik
Thanks for the whole process, but I'm currently stuck at step nr. 7. I don't really understand, what do you mean by "Connect the terminal application to the serial port for your board."
How are we supposed to do that?
Coding Badly
#154
Nov 15, 2016, 05:02 pm Last Edit: Nov 15, 2016, 05:02 pm by Coding Badly
Mocivnik
Hmm, that's it? Okay, got connected. But still, wasn't able to do anything actually.
Considering changing 1. Atmel and then 2. FTDI.
MAS3
If you see your typed texts in terminal, you do not need to change the FTDI.
That's what this thread is all about: figuring out whether your USB/serial chip (for you FTDI) works or not.
If you do not see anything, suspect FTDI and anything it depends on (assuming you did all steps correctly).
The latter doesn't mean Atmel is OK.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
martymarty
As a novice to Arduino I have the following questions regarding:
http://forum.arduino.cc/index.php?topic=73748.0
< Loop-Back Test Instructions >
QUESTION
      " 6. Start your favourite terminal application.  Serial Monitor will work fine."
Q1:does (6) mean:  Clk on Serial Monitor icon top, right hand edge of Arduino IDE screen?
      "7. Connect the terminal application to the serial port for your board.
Q2:does (7) mean: perform the procedure described in (8)"Send data..." ;
 the data should be echoed back to the Serial Monitor from the Arduino UNO
marty
email:  hawkeye@013net.net
Coding Badly
Do not cross-post.  Other thread removed.
Coding Badly
#159
Mar 07, 2017, 09:09 am Last Edit: Mar 07, 2017, 09:09 am by Coding Badly
Yes.
Quote
No.  When using Serial Monitor you have to select the serial port before opening Serial Monitor.  In the IDE click Tools then Port then the serial port associated with your board.
bkmtech
Couldn't you just disconnect the Serial Converter and loop back right there.
larryd
What happened when you tried?
"Serial Converter"
What converter?
No technical PMs.
The last thing you did is where you should start looking.
ballscrewbob
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Djongambo
There should be a remark in the loopback instruction showing to the solution found in https://forum.arduino.cc/index.php?topic=492655.0 (removing the RX/TX LEDs from Arduino Nano Clones) to make the serial loopback test work. Would have saved me some hours ;-)
MAS3
#164
Dec 24, 2018, 01:21 am Last Edit: Dec 24, 2018, 01:22 am by MAS3
Hi Djongambo, and welcome.
I don't agree with the word "should", and your description to the affected boards ("clones") is too general.
All i've seen so far (i just learned this from your remark), is that this problem only occurs with CH340 USB-Serial chips, under certain circumstances.
Also, the datasheet of that chip (click!) doesn't mention RX or TX LEDs anywhere.
So connecting these LEDs directly to the i/o pins, is out of specification.
But it is a dirty cheap way to have these LEDs anyone using an Arduino wants, so that is what those manufacturers do.
You'll choose the cheapest of all clones (i would), so the 0.2 cents they'd need for the extra pair of transistors so this problem goes away, can't be spared.
So first of all this is a problem you get for free when ordering the cheapest board you can find.
You can't expect the members of this forum, or Arduino to know all problems with all hardware clones or software clones (or "forks") around the world.
But you can point to a problem and its solution if you have one, and request to have that incorporated in threads like these.
There's a slight difference between a request and telling someone "what should be".
