Seattle, WA USA
Seattle, WA USA
« Reply #45 on: October 09, 2011, 06:32:02 pm » |
How's this for the introduction... Needs a comma between "host computer" and "hardware driver". It is testing all 4 items.
Dallas
Shannon Member
« Reply #46 on: October 09, 2011, 07:02:56 pm » |
Thanks! Done.
Cairns - Green Island for Winter
« Reply #47 on: October 15, 2011, 03:48:30 pm » |
I tried the procedure and had no difficulty following it. Excellent! Thank you. The slight change I wanted to suggest was that some of the text in step 8 should be removed Nope. Not going to happen. My Tech-Com II professor stated repeatedly: You tell it to them three times. You tell them what you are going to tell them in the introduction. Then you tell them in the body. Then you tell them what you told them in the conclusion. After working in technical support for a few years, I strongly agree. Some people get it the first time they read something. Some people barely get it the third time they read something. Troubleshooting instructions need to be written for the latter group; lots of repetition. and instead there should be a short introduction saying why you would do the test and what it would achieve I agree. It needs an introduction / cover. Suggested text at the start (removing equivalent text in point 8 ); The loopback test will prove that your host computer hardware driver, USB cable, and USB to serial converter are all working. Try the loopback test after you first install the system or if you cannot upload sketches. Is it necessary to perform a loop-back test after first installing the system? So treat everybody like dummies because there might be one or two in a dozen ! How did the dummies get into your professors class? When I went to uni it was stay up or get out
Governments should do what they were designed to do only. Manage the larger issues best done by Government. My Family and my Property are not Government issues. To stop corruption give them 3 times the normal penalty. Have them agree on first appointment.
New River, Arizona
« Reply #48 on: October 15, 2011, 05:30:25 pm » |
Not everyone that needs repetition is a dummy. Some folks read this board in their second or third language. Some folks use google translate to read it. Some folks are beginners at everything electronic. Like it or not, repetition works. It gives the person a second chance to hear it, it gives the translator a new version to try and screw up differently and it helps to reinforce information.
Besides, being snide doesn't help.
Dallas
Shannon Member
« Reply #49 on: October 19, 2011, 02:01:12 pm » |
New River, Arizona
« Reply #50 on: October 19, 2011, 04:07:16 pm » |
I like the introduction. Short, and to the point.
I have mixed feelings about the examples, they might confuse more than help. I'll bow to other's opinions on that.
Good job.
Dallas
Shannon Member
« Reply #51 on: October 21, 2011, 01:52:22 am » |
Introduction added.
Any more comments about examples / related topics?
Any other use-cases?
Montreal
« Reply #52 on: November 22, 2011, 08:47:45 pm » |
Should try without the jumper as the Terminal program could have a ECHO turn on Patgadget
Patgadget Montreal
"The old Europe"
Bootloaders suck!
« Reply #53 on: December 27, 2011, 10:43:17 am » |
There have been issues with 'clone' boards lately.
They didn't come with either the ATmega8u2 or the FT232R, but with some IC by 'Prolific'. Suffice to say people were still trying to install the FTDI drivers or the .inf file, depending on what their clone pretended to be.
Maybe there could be a note/hint to check the vendor/product IDs if the 'Arduino driver' refuses to install.
Addendum:
Of course we could say "why should we care?", but in the end people with these modified clone boards end up here and we spend our time that would be better spent elsewhere.
« Last Edit: December 29, 2011, 02:45:35 pm by madworm »
• Upload doesn't work? Do a loop-back test. • There's absolutely NO excuse for not having an ISP! • Your AVR needs a brain surgery? Use the online FUSE calculator. • My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets... • Microsoft is not the answer. It is the question, and the answer is NO!
« Reply #54 on: December 30, 2011, 01:59:04 am » |
"Force the processor to remain in reset by connecting a jumper from RESET to GND"
How do you do this? Have any pictures :-)
Boston area, metrowest
« Reply #55 on: December 30, 2011, 03:07:13 am » |
Put a piece of wire in the header pin labelled Reset, and the other end in one of three headers pins labelled GND.
"The old Europe"
Bootloaders suck!
« Reply #56 on: December 30, 2011, 03:16:03 am » |
There's no picture of the wire!
Before a wire can be used, it must be properly declared and defined.
« Reply #57 on: January 17, 2012, 05:12:25 pm » |
Well, this explains the test but not what to do when it fails, so its really not an explanation at all
Dallas
Shannon Member
« Reply #58 on: January 17, 2012, 06:29:05 pm » |
@stargazer2050: If you would like help or to affect a change you will have to provide more information.
« Reply #59 on: January 30, 2012, 02:01:19 pm » |
not even stickey
OSX 6.5.8 (fresh install)
Board 1 -- Arduino Mega Failed loopback test Board 2 -- Arduino Mega Failed loopback test Board 3 -- Arduino Uno Failed loopback test Board 4 -- Arduino Uno Passed loopback test
Arduino 1.0
I have three boards which are no longer working: They were working fine at least 12 hours ago:
all three failed the loopback test. One did not even register with a usb serial connection.
This has been tried on at least 3 computers so far
any advice would be helpful
