Topic: Datalogger project (Read 981 times) previous topic - next topic
galindro
Hi!
   I need to build a datalogger project. Here are the details of the project:
1 - collect data from sensors
2 - put then into a SD card (with date/time)
3 - sent then via gsm/gprs to an ftp server (or via http post)
   I have searched for shields that can do this job for me. Here are:
http://www.sparkfun.com/products/9607
http://www.nuelectronics.com/estore/index.php?main_page=product_info&cPath=7&products_id=20
   My doubt is about the power consumption of both shields.
http://www.sparkfun.com/datasheets/CellularShield/SM5100B%20Datasheet.pdf <- This is the GSM/GPRS shield's datasheet. You will see a section called "power consumption". I some cases, it can consumes 2A!
http://www.nuelectronics.com/download/projects/sensor_shield_v1.0.pdf <- This is the sensor shield's datasheet. Unfortunately it donĀ“t provide any power consumption information...
   AFAIK, my Arduino 2009 can provide only 500mA via either the USB connection or the external power jack, and some of that is required by the Arduino itself.  Then how can I put these shields to work together?
Chagrin
To get your required 2A you just need to add an additional regulator to your project. Something like this would work, and you'd connect its output to +5V on your Arduino.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
