Topic: "Car-duino" Mk1 (Read 1 time) previous topic - next topic
Carlz0r
Hey all. Other than a little bit of HTML/PHP scripting this is my first real foray into programming. I'm working on what I call my "Car-duino". Essentially, I would like it to run a couple different things:
-Two servos being used to operate a retractable front license plate
-Brake lights and progressive turn signals
While it does work, the use of delay() is causing some issues, and I can't for the life of me figure out how to properly replace the timing using millis(). Also, I'm sure there's a better way to organize it rather than using all the if/else statements but that'll take some more learning on my part.
The main problem I'm having with the delay function is the amount of time it takes for the brake lights to turn on or off. From what I've read it seems like I should be able to use millis() instead, or possibly even an interrupt.
Code: [Select]
#include <Servo.h>
Servo servoA;
Servo servoB;
const int lpPin = 0;
const int bPin = 3;
int switchState = 0;
int brakeState = 0;
int lastswitchState = 0;
const int llaPin = 9;
const int llbPin = 10;
const int llcPin = 11;
const int rlaPin = 8;
const int rlbPin = 7;
const int rlcPin = 6;
const int lsPin = 2;
const int rsPin = 1;
int rsState = 0;
int lsState = 0;
servoA.attach(12);
servoB.attach(13);
pinMode(lpPin, INPUT);
servoA.write(0);
servoB.write(0);
pinMode(lsPin, INPUT);
pinMode(rsPin, INPUT);
pinMode(bPin, INPUT);
pinMode(llaPin, OUTPUT);
pinMode(llbPin, OUTPUT);
pinMode(llcPin, OUTPUT);
pinMode(rlaPin, OUTPUT);
pinMode(rlbPin, OUTPUT);
pinMode(rlcPin, OUTPUT);
switchState = digitalRead(lpPin);
lsState = digitalRead(lsPin);
rsState = digitalRead(rsPin);
brakeState = digitalRead(bPin);
if (brakeState == LOW){
if (lsState == HIGH && rsState == LOW)
digitalWrite(llaPin, HIGH);
delay(750);
digitalWrite(llbPin, HIGH);
delay(750);
digitalWrite(llcPin, HIGH);
delay(750);
digitalWrite(llaPin, LOW);
digitalWrite(llbPin, LOW);
digitalWrite(llcPin, LOW);
delay(750);
else if (rsState == HIGH && lsState == LOW)
digitalWrite(rlaPin, HIGH);
delay(750);
digitalWrite(rlbPin, HIGH);
delay(750);
digitalWrite(rlcPin, HIGH);
delay(750);
digitalWrite(rlaPin, LOW);
digitalWrite(rlbPin, LOW);
digitalWrite(rlcPin, LOW);
delay(750);
else if (lsState == HIGH && rsState == HIGH)
delay(750);
delay(750);
delay(750);
delay(750);
if (brakeState == HIGH) {
delay(750);
delay(750);
delay(750);
delay(750);
delay(750);
delay(750);
delay(750);
delay(750);
else {
if (switchState != lastswitchState)
if (switchState == HIGH)
servoA.write(180);
delay(4000);
servoB.write(90);
if (switchState == LOW)
servoB.write(0);
delay(2000);
servoA.write(0);
lastswitchState = switchState;
As you can see it's a bit of a mess but any pointers would be greatly appreciated. Thanks!
liudr
Quote
Are you sure that is legal in your country/region?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Carlz0r
Quote
The rectractability is legal, and the plate will be out while on public roads. However, I'm going to be taking the car to the track and shows quite often and it'd be cool to just flip a switch and fold it away.
Chagrin
...or a library, like SimpleTimer.
Carlz0r
That looks perfect! Thanks, I'll give that a shot.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
