Loading...
Pages: 1 [2] 3 4   Go Down
Author Topic: REALLY simple wireless?  (Read 2404 times)
Connecticut
Offline Offline
Edison Member
RTFD (Datasheet in our case)
View Profile
Right now, though, I don't care so much about the frequency, I am just wondering how I could design a circuit to transmit wireless signals, from there I could change the frequency. Could I use a 555 timer, maybe?
Logged
I'm not kidding. If I am asking a question whose answer is found within the concerned product's datasheet, shame on me. If I am answering a similar question, shame on you!
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
No, not stable enough and will not work at high enough frequency.
Can you take a hint, this project is a non starter, with things like a 555 timer it's not going to be legal even in the US
Logged
Connecticut
Offline Offline
Edison Member
View Profile
So it is impossible to do micro free wireless. Alright.
I suppose I can just use on of the rf link units once they come back in stock on sparkfun...
baum
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Sparkfun: don't hold your breath, I have not seen the receivers there since August.
Try the $5 pair, or the next one up.
Want a simple transmitter? Get a "high" voltage, and let it spark to ground - then get a simple AM radio and listen for  the burst of interference that comes in.  Not really practical tho.
If you can make a circuit oscillate, it can be a transmitter, whether intentional or not.
Being able to reliably tune in that transmitter and pick out a piece of data is the hard part.
One way is to have transmitter is transmitting continuously and your receiver tuned into it, and then detect a difference in the signal and report that as different state.
If you're not transmitting  continuously, that makes it harder for the receiver as now it not only has to tune, it has to determine the 2 seperate valid states.
That's the nice part about virtualwire, it takes care of getting enough sent for the receiver to do its job.
Designing RF that works from scratch without tools and the engineering background is very difficult.
Here's a simple thing you can try
http://www.sciencebuddies.org/science-fair-projects/project_ideas/Elec_p024.shtml
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Online Online
Brattain Member
View Profile
WWW
Quote
As well as being not practical, spark transmitters as they are called are illegal in every country in the world.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Lots of stuff is illegal, doesn't stop people from doing it tho.
I would think not being at all useful would be more of a deterrent.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
The 434s also, same price
http://www.robotshop.com/433mhz-transmitter-receiver-pair.html
And a High Sensitivity set for 80 cents more, higher data rate
http://www.robotshop.com/433mhz-high-sensitivity-transmitter-receiver-pair-rxa33.html
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
And a Seeedstudio version as well for $4.99
http://www.robotshop.com/seeedstudio-433mhz-low-cost-transmitter-receiver-pair-3.html
Logged
UK
Offline Offline
Sr. Member
Arduino - very interesting !
View Profile
i have been using that style with the virtualwire library with great success
(I think Marconi used a spark transmitter to transmit the first signal over the atlantic !)
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
I suspect he wasn't too concerned about EMC back then.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Leighton Buzzard, UK
Offline Offline
Edison Member
View Profile
and no-one else was transmitting!
Logged
there are only 10 types of people
them that understands binary
and them that doesn't
Chester, UK
Offline Offline
Sr. Member
Trying to return the love to none logic level MOSFETS
View Profile
Thought they just gave it a cool acronym and reduced the power? (UWB)
Logged
If your system involves lethal voltages/life critical/flamable elements - you probably shouldn't need to ask.
The Arduino != PC.
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
If you build a 'simple' RF link and get it wrong you might block emergency services' or aircraft frequencies... This is illegal and irresponsible.  Buy a pre-built approved module (or become a radio amateur and learn to do it properly - less simple)
Logged
Connecticut
Offline Offline
Edison Member
View Profile
I'll just get a Nordic.
Logged
Connecticut
Offline Offline
Edison Member
View Profile
We just got an ad. It showed up on the notification email, not here, though. I guess someone erased it.
Quote
I think I really learned from this site a lot of important information and hope this site will be more to do better.
oakley store
oakley prescription
oakley dispatch
cheap oakley sunglasses
cheap oakley
ED Hardy Clothes
ED Hardy Bags
What was the point of that?
And where did they get "oakley" from?!?!?!?!?!?
baum
Logged
Pages: 1 [2] 3 4   Go Up
Print
Jump to:
