Loading...
Pages: [1] 2   Go Down
Author Topic: Eclipse IDE C++ and Serial.begin()/print/whatever wants to destroy my life  (Read 5584 times)
Offline Offline
Newbie
View Profile
Hi, i am just starting a small project conserning LEDs and cubes. http://dl.dropbox.com/u/419037/purpleorange.png
But nevermind that, I am having troubles using Serial.print() in a C++ enviornment in Eclipse. I thought it would work more or less the same as the other functions, I am having no trouble with digitalRead/Write etc.
ive built the libraries myself, and followed the eclipse guide to get myself up and running with AVR.
Here is a successful build without any use of Serial.*
http://pastebin.com/kT0rnDDz
I dont think the fact that im building as debug should be any issue, ive tried building as release with a different guide.
http://dl.dropbox.com/u/419037/screen1.png
With the Serial.begin()
Description   Resource   Path   Location   Type
make: *** [BlinkExample.elf] Error 1   BlinkExample          C/C++ Problem
Method 'begin' could not be resolved   main.cpp   /BlinkExample   line 38   Semantic Error
Symbol 'Serial' could not be resolved   main.cpp   /BlinkExample   line 38   Semantic Error
Probably something silly, any advice would be appreciated.
Logged
Centurion RSA
Offline Offline
Full Member
Arduino rocks
View Profile
I assume that you compiled the core functions into a library without the main loop stuff and that you compiled the core library with the same clock frequency settings as your current project. You also compiled it for the same chip.
Logged
Rather people think you to be a fool than you open your mouth and confirm it.
Offline Offline
Newbie
View Profile
Yes 16mzh and at328p chip for lé Uno.
Logged
Guildford, UK
Offline Offline
Full Member
Arduino rocks
View Profile
Sounds like you've not defined the global object Serial. In the Arduino environment this is defined in HardwareSerial.h / HardwareSerial.cpp
Have you got this file in your library?
If so are you including HardwareSerial.h or WProgram.h?
Remember that eclipse isn't like the Arduino IDE. It doesn't do anything for you. You HAVE to include all the headers yourself, declare all functions and include all libraries for the linker.
Iain
Logged
Centurion RSA
Offline Offline
Full Member
Arduino rocks
View Profile
Have a look at this post, I added a zip file that contains a template and all the settings that you need to get going.
http://arduino.cc/forum/index.php/topic,66169.0.html
Marius
Logged
Offline Offline
Newbie
View Profile
Tried having a look at those files. Only path that needed obvious changing was the c:\users\marius ones.
But still, getting linking errors.
What AVR are you using?
Logged
Guildford, UK
Offline Offline
Full Member
Arduino rocks
View Profile
Quote
Has your error message changed?
In your original post you are getting a compilation error.
Iain
Logged
Centurion RSA
Offline Offline
Full Member
Arduino rocks
View Profile
I am using the 328p at 16mHz.
The main() must be in your application and not in the core library.
Logged
Offline Offline
Newbie
View Profile
I have exactly the same problem. I can use eclipse to compile->build->upload the "blink" example.
However as soon as I try use "Serial", the compiler gives the following error:
Code:
Symbol 'Serial' could not be resolved main.cpp line 10 Semantic Error
I use the library that arduino ide generates (copied from /tmp). I also included every .h file that I found under <Arduino>/ directory to the eclipse project. But still I get the same error.
Does anyone know the reason for this? How may I solve this problem?
Logged
Guildford, UK
Offline Offline
Full Member
Arduino rocks
View Profile
You need to include HardwareSerial.h:
Quote
#include "HardwareSerial.h"
You may need to include a path in front of the file if it's in a different location. For example in my setup I need to use
Quote
#include "Arduino/HardwareSerial.h"
as I've built the Arduino library in an Arduino folder in my workspace.
Iain
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Has anyone resolved this problem as I am experiencing the same thing.
B2
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Well I added the following to the top of my sketch:
  extern HardwareSerial Serial;
And now it builds just fine.
B2
Logged
Offline Offline
Newbie
View Profile
No special options are required, but some settings in eclipse and the general project setup are critical. Declaring HardwareSerial extern or some such thing is definitely not required, you must have a broken setup.
Look here for a detailed explanation:
http://www.arduino.cc/playground/Code/Eclipse
Be aware that there are quite a few bugs in the eclipse AVR plugin, and some in the eclipse CDT plugin which the AVR one is based on.
Logged
Centurion RSA
Offline Offline
Full Member
Arduino rocks
View Profile
I agree with KiwiDude, you need not make special declarations. Have a look at this template workspace for Adruino that I created.
https://github.com/mariusl/Eclipse-for-AVR
Place all three projects in the same work space. Compile each of the projects starting with the ArduinoCore and then the AdruinoLibraries and lastly the Template.
I use this work space for all my projects and never have any issues. I import libraries from the arduino/libraries directory when I need a new one. Recompile and go.
Logged
Offline Offline
Newbie
View Profile
Marius, your template archive is an interesting idea but falls flat in several ways. Your path configuration works only on doze, and only if someone installs the same way as you. Use workspace-relative paths. Your example includes Wprogram.h which barfs on anything but the one OS around that is case-insensitive. The SD library in there compiled with errors. I didn't look further, but eclipse thought boolean was undefined.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
