Topic: Email attachments from arduino as an SMTP client (Read 21549 times) previous topic - next topic
btsp
okay i figured that out too, here's a post Incase someone is wondering.
Sending Multiple Attachments
    Serial.println("connected");
                       client.println("HELO itismeletschat"); /* say hello (statement after helo is needed but irrelevant)*/
                         delay(wait); /* wait for a response */
                       client.println("MAIL From: blank@gmx.com"); /* identify sender, this should be the same as the smtp server you are using */
                       client.println("RCPT To: blank@virelec.com"); /* identify recipient */
                       client.println("DATA");
                       client.println("Subject: text file attached");
                       [b]client.print("Content-type: multipart/mixed; boundary=\"$boundary\" \r\n");[/b]
                       [b]client.print("--$boundary\r\n");[/b]
                       datatxt =SD.open("HEAD2.csv",FILE_READ);
                       client.print("Content-Type: csv; name=\"HEAD2.csv\"\r\nContent-Disposition: attachment; filename=\"HEAD2.csv\"\r\nContent-Transfer-Encoding: base64\r\n\r\n");
                       encode();
                       datatxt.close();
                       delay(wait);
                       datatxt =SD.open("meow.txt",FILE_READ);
                       client.print("Content-Type: txt; name=\"meow.txt\"\r\nContent-Disposition: attachment; filename=\"meow.txt\"\r\nContent-Transfer-Encoding: base64\r\n\r\n");
                       encode();
                       datatxt.close();
                       client.println("."); /* end email */
                       client.println("QUIT"); /* terminate connection */
PaulS
If you are waiting for a response, shouldn't you then read the response? Or else remove the incorrect comment. Even better, remove the useless delay() calls.
primate
Some [older] SMTP servers don't support pipelining (i.e. receiving a new command before the current command is responded to), and even for servers that support pipelining, some commands are in herently not pipelineable, so sending commands in quick succession without a bit of delay might be problematic (especially if the sketch is not handling server errors. It might be safer to keep some sort of delay.
Not reading the server response should not be a big deal and the receive buffer should just fill up with unread responses. Downside is of course it can't process server errors. I'm not sure how the Serial stack on the Arduino handles full buffers but if it follows general parctice it will just silently drop the new bytes.
I think the safer way (if reliability is an issue), is to replace the constant wait with a function call that loops to wait for client.available() > 0, and just read and discard the bytes beefore sending the next command. This ensures the server had responded, and to account for transient network delays that causes replies to come back more than the constant wait period.
I realized that I might be getting off topic here ...
PaulS
No, I think you are properly discussing the actions that need to be performed, instead of just blindly waiting what might be just enough time, not near enough time, or way too long.
dazer
So testing the above code, I still cannot get any "attachment" to my email.
  client.println("Subject: Arduino attachment email test\r\n");
  picture = SD.open("data.txt", FILE_READ);
  client.print("Content-Type: txt; name=\"data.txt\"\r\nContent-Disposition: attachment; filename=\"data.txt\"\r\nContent-Transfer-Encoding: base64\r\n\r\n");
  encode();
  if(!eRcv()) return 0;
  Serial.println(F("Sending QUIT"));
  strcpy_P(tBuf,PSTR("QUIT\r\n"));
  client.write(tBuf);
  client.stop();
  Serial.println(F("disconnected"));
  return 1;
void encodeblock(unsigned char in[3], unsigned char out[4], int len) {
  out[0] = cb64[in[0] >> 2]; out[1] = cb64[((in[0] & 0x03) << 4) | ((in[1] & 0xF0) >> 4)];
  out[2] = (unsigned char) (len > 1 ? cb64[((in[1] & 0x0F) << 2) | ((in[2] & 0xC0) >> 6)] : '=');
  out[3] = (unsigned char) (len > 2 ? cb64[in[2] & 0x3F] : '=');
void encode() {
  unsigned char in[3], out[4]; int i, len, blocksout = 0;
  while (picture.available() != 0) {
    len = 0; for (i = 0; i < 3; i++) {
      in[i] = (unsigned char) picture.read();
      if (picture.available() != 0) len++;
      else in[i] = 0;
    if (len) {
      encodeblock(in, out, len);
      for (i = 0; i < 4; i++) client.write(out[i]);
      blocksout++;
    if (blocksout >= 19 || picture.available() == 0) {
      if (blocksout) client.print("\r\n");
      blocksout = 0;
This code just inserts some garbage characters on my email. It should ideally attach the file data.txt
 encode();
 client.print("\r\n.\r\nQUIT\n");
 client.stop();
 datatxt.close();
 while(1);
void encodeblock(unsigned char in[3],unsigned char out[4],int len) {
 out[0]=cb64[in[0]>>2]; out[1]=cb64[((in[0]&0x03)<<4)|((in[1]&0xF0)>>4)];
 out[2]=(unsigned char) (len>1 ? cb64[((in[1]&0x0F)<<2)|((in[2]&0xC0)>>6)] : '=');
 out[3]=(unsigned char) (len>2 ? cb64[in[2]&0x3F] : '=');
void encode() {
 unsigned char in[3],out[4];
 int i,len,blocksout=0;
 while (datatxt.available()!=0) {
   len=0;
     for (i=0;i<3;i++){
           in[i]=(unsigned char) datatxt.read();
               if (datatxt.available()!=0) len++;
                     else in[i]=0;
     if (len){
         encodeblock(in,out,len);
          for(i=0;i<4;i++) client.write(out[i]);
               blocksout++; }
     if (blocksout>=19||datatxt.available()==0){
         if (blocksout) client.print("\r\n");  blocksout=0;
This code on the other hand does the 64 bit encoding but it does not appear as an attachment. It just prints the values in the body of my email.
Am I understanding this wrong an attachment would not be an "attachment" but would appear in the body of the email?
SurferTim
This is how I send a text file attachment from my SD card.
  client.println("Subject: Arduino email image");
// this is new
  client.write("MIME-Version: 1.0\r\n");
  client.write("Content-Type: Multipart/mixed; boundary=frontier\r\n\r\n");
  client.write("--frontier\r\n");
  client.write("Content-Type: text/plain\r\n\r\n");
  client.write("This is an inage from my Arduino!\r\n");
  client.write("Content-Type: text/plain\r\n");
  client.write("Content-Disposition: attachment; filename=test.txt\r\n\r\n");
// this is where you would send your file
  int clientCount = 0;
  File myFile = SD.open("test.txt");
  if(myFile) {
    while(myFile.available()) {
      clientCount = myFile.read(tBuf,64);
      client.write((byte*)tBuf,clientCount);
    myFile.close();
  else {
    Serial.println(F("File open failed"));
  client.write("--frontier--\r\n");
// end of new
// send a period on a line by itself
dazer
Hey Tim, that works a charm :)  on text messages. However when I tried to send an image the image is sent all smudged up:
The code is used is:
// this is new
  client.write("Content-Type: image/jpg\r\n\r\n");
  client.write("This is an image from my Arduino!\r\n");
  client.write("Content-Type: image/jpg\r\n");
  client.write("Content-Disposition: attachment; filename=picture.jpg\r\n\r\n");
//  File myFile = SD.open("test.txt");
  File myFile = SD.open("picture.jpg");
  if(myFile) {
    myFile.close();
  else {
// end of new
  client.write(tBuf);
  client.stop();
Any pointers ? Thanks a ton.
dazer
Ok just wondering
  if(myFile) {
If i play with the value 64 the email does not get sent even if I adjust char tBuf[64];
Can I do away with the buffer concept altogether or increase its size while sending the image?
SurferTim
I think you must base64 encode the image to send it as an email attachment. Don't have much time to test today, but I'll work on it when I can.
dazer
Thank you for your reply Tim.  I did try the base 64 encoding using the code posted by Razorblade but was not successful. However, i did notice that when I did send images using the code you posted .txt files, the resultant files were not the same.
I opened both the original file and the attachment of the same file that i received in my email in a hex editor.
0x0D in the original were replaced by 0x0A in the attachment at various locations.
I have attached both the files.
Why is this usually done?
Thanks in advance.
aarg
Because many byte values are not printable characters.
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
dazer
Ah! now that makes sense. Thank you for your reply.
dazer
Tim, I kinda figured out a few things out.
Firstly if i remove the
      blocksout = 0;
the base 64 encoding gets properly fomatted.
2) In your code the last SMTP command
gets inserted into the attached jpeg file at the end and hence the received file become unreadable.
This is my code snippet:
client.println("Subject: Arduino email encoded image");
  // this is new
  client.write("This is a Image encoded attachment from my Arduino!\r\n");
  client.write("Content-Type: image/jpeg\r\n");
  client.write("Content-Disposition: attachment; filename=picture.jpg\r\n");
  client.write("Content-Transfer-Encoding: base64\r\n\r\n");
  if (myFile) {
    while (myFile.available()) {
//      clientCount = myFile.read(tBuf, 64);
//      client.write((byte*)tBuf, clientCount);
      encode();
    myFile.close();
  else {
    while(1);
//  client.write("\n"); //added
  // end of new
  if (!eRcv()) return 0;
  strcpy_P(tBuf, PSTR("QUIT\r\n"));
  client.write(tBuf);
  client.stop();
  return 1;
void encode() {
  while (myFile.available() != 0) {
      in[i] = (unsigned char) myFile.read();
      if (myFile.available() != 0) len++;
      else in[i] = 0;
    if (len) {
      blocksout++;
//    if (blocksout >= 19 || myFile.available() == 0) {
//      if (blocksout) client.print("\r\n");
//      blocksout = 0;
Any clues?
Zyphel
I'm using this encode routine from Razorblades post #18 in this thread (thanks...quoted below) and sending an email with attachment successfully, but I'm getting nowhere near the 50kb/30second speed indicated.
Running on a mega2560 with cc3000 wifi board sending a 5k text file is taking 3 minutes to encode.
Has anyone else seen this kind of time to encode?
(from Post #18)
This would be the whole program. Reads picture.jpg from microSD card, sends an e-mail with picture.jpg attachment:
Code: (example.ino) [Select]
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
byte MAC[]={0x,0x,0x,0x,0x,0x};  // Your MAC
File picture; Client client;
static const char cb64[]="ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/";
void encode() {
  unsigned char in[3],out[4]; int i,len,blocksout=0;
  while (picture.available()!=0) {
    len=0; for (i=0;i<3;i++) { in[i]=(unsigned char) picture.read(); if (picture.available()!=0) len++; else in[i]=0; }
    if (len) { encodeblock(in,out,len); for(i=0;i<4;i++) client.write(out[i]); blocksout++; }
    if (blocksout>=19||picture.available()==0) { if (blocksout) client.print("\r\n");  blocksout=0; }
  Ethernet.begin(MAC); delay(2000);
  pinMode(10,OUTPUT); SD.begin(4);
  picture=SD.open("picture.jpg",FILE_READ);
  client.connect("smtp.mail.yahoo.com",25);
  client.print("HELO\nAUTH PLAIN\nxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\r\n");  // x: base64 encoded login: \0foo@yahoo.com\0password
  client.print("MAIL FROM:<foo@yahoo.com>\nRCPT TO:<bar@fakemail.com>\nDATA\nFrom: \"Foo\" <foo@yahoo.com>\r\nTo: bar@fakemail.com\r\nSubject: Picture attached\r\n");
  client.print("Content-Type: image/jpeg; name=\"picture.jpg\"\r\nContent-Disposition: attachment; filename=\"picture.jpg\"\r\nContent-Transfer-Encoding: base64\r\n\r\n");
  encode();
  client.stop();
  picture.close();
  while(1);
Takes less than 30 seconds to send a 50 KiB picture.
[/quote]
idp1
hey Tim, may i know what what does tbuf refer to ? it is on this line
i have error when compiling code, stat:
send.ino: In function 'void setup()':
send:72: error: 'tBuf' was not declared in this scope
