Topic: SOLVED:LMS303 sample reading (Read 2946 times) previous topic - next topic
btsp
Jul 27, 2011, 04:55 pm Last Edit: Aug 03, 2011, 10:32 pm by btsp Reason: 1
I am using a LMS303 on a polo breakout board using the Lib available in the playground with my own calibration added
the heading readings are a bit jumpy, +3 degree range pretty much,
i was wanting to sample the readings then get the average
but if you do that with heading readings when it gets around to the 360 mark and you are jumping to 1 again, if you average those you are way off.
example:  (360+359+360+1+360 + 1)/6 = 240
is their another way i can go about this to get my readings a bit more accurate?
btsp
would something along the lines of somehow reading in quadrants?
quad 1 :0-90  ( 0-90 degrees)
quad 2 :90-0  (90-180 degrees)
quad 3 :0-90  (180-270 degrees)
quad 4 :90-0  (270-360 degrees)
if i could indicate which quadrant they are coming from..does this sound like it should work?
Graynomad
#2
Jul 27, 2011, 06:22 pm Last Edit: Jul 28, 2011, 01:37 am by Graynomad Reason: 1
There's probably a really simple mathematical way to do this, but maths isn't my strong point so maybe the following brute-strength approach.
It's only a problem in the 360/0 boundary area. So let's define a band around that of maybe +-10, ie 350 to 10. Any readings outside this band are treated normally.
However if you get readings inside the band you switch to a mode that adds 360 to any values < 350, does the averaging, then subtracts 360 if the results is > 360.
If you get an average that falls outside the band you revert to the standard method.
(360+359+360+(1+360)+360 + (1+360))/6 = 360
(358+359+(5+360)+(4+360)+(3+360)+(1+360))/6 = 361.8, subtract 360 = 1.8
EDIT: all 360s should probably be 359s.
______
Rob
btsp
ah nice idea thank you
i made a code that seems to work at the moment.
This will not work if there is odd spikes in the readings, but that's alright ill be able to ignore those.
int total = 0;
      for (int _sample = 0; _sample < 10; _sample++) {
        read(); // read the magnometer values
heading_samples[_sample] = heading((vector){0,-1,0}); //create heading
         if ( (heading_samples[_sample] > 350 ) || (heading_samples[_sample] < 10 )){
                hstate = 1;
         if (hstate != 1)
                 hstate = 2; //if no numbers above 350 or below 10 take normal average
          switch(hstate)
                case 1:
                     for(int _sample = 0; _sample < 10; _sample++){
                          if ( heading_samples[_sample]  < 350 )
                                  heading_samples[_sample] += 360; //add 360 if below 10
                         total += heading_samples[_sample];  //sum up readings
                       total /= 10;
                       heading  = total;
                      if (heading >= 360){
                      heading - 360;
                      return heading
                      hstate =0;
                      break;
                case 2:
                           total /= 10;
                           heading  = total;
                           hstate =0;
   return heading
                          break;
any suggestions to clean up code please do
thanks again
Graynomad
I had a think about this after switching off my computer last night. I think all you need to detect is the case when 2 or more readings differ by more than the expected jitter.
So I modified your code to do this, plus simplified the rest of the code. I hope I didn't stuff it up on the process :)
#define FUDGE_FACTOR 100  // any number > the expected jitter will do
#define SPECIAL 1
#define NORMAL 2
#define N_SAMPLES 10
#define BAND 10
int heading_samples[N_SAMPLES];
int hstate;
// dummy funcs just to get it to compile
void setup () {}
void loop () {}
int read () {}
int getHeading () {
  int total = 0, min = 0, max = 0;
  for (int _sample = 0; _sample < N_SAMPLES; _sample++) {
    // I don't have "vector" so commented the next line out
//heading_samples[_sample] = heading((vector){0,-1,0}); //create heading
    if (heading_samples[_sample] < min) min = heading_samples[_sample];
    if (heading_samples[_sample] > max) max = heading_samples[_sample];
    hstate = (max - min > FUDGE_FACTOR) ? SPECIAL : NORMAL;
  for(int _sample = 0; _sample < N_SAMPLES; _sample++){
    if ( heading_samples[_sample] < 360 - BAND && hstate == SPECIAL)
      total += 360; //add 360 if not above 350
  total /= N_SAMPLES;
  if (total >= 360){
    total -= 360;
  return total;
______
Rob
btsp
Rob,
thanks for simplifying the code i am yet to test it out but just a question,
what does:
that do?
Graynomad
#6
Jul 28, 2011, 04:56 pm Last Edit: Jul 28, 2011, 05:05 pm by Graynomad Reason: 1
It's a shorthand version of
if (max - min > FUDGE_FACTOR)
  hstate = SPECIAL;
  hstate = NORMAL;
It's called a ternary operator
x = test ? true_result : false_result;
http://cprogramminglanguage.net/c-ternary-operator.aspx
much like IIF in many other languages.
______
Rob
btsp
ah thanks.
well ran the code, everything is good except around the 350 mark.
I am going to look into it more and get back to you
btsp
#8
Jul 28, 2011, 05:46 pm Last Edit: Jul 28, 2011, 05:59 pm by btsp Reason: 1
found the error,
was the max/min reset values.
had min and max both at 0
min should be at 359 and max at 0.
she works great now,
thanks again
Graynomad
No problems, I might file that away for future use myself :)
______
Rob
