Topic: RLC Filter : Series vs Parallel ? (Read 1 time) previous topic - next topic
screw32
In learning about RLC filters, I was wondering if there is an advantage/disavantage to using a series circuit vs a parallel circuit (tank circuit: L and C)? Is one more common than the other?
retrolefty
They both have their uses, a lot depends on the impedance level of the source and load. In the arduino world one deals mostly with simple low pass filters for lowering noise for analog inputs or for converting PWM outputs to true analog output voltages.
Lefty
Grumpy_Mike
Not only are there parallel and series but there are other combinations as well, see towards the end of this page:-
http://en.wikipedia.org/wiki/RLC_circuit
The difference is whether you want a short circuit or open circuit (low impedance or high impedance) at the resonant frequency and that depends on the application.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
