Topic: Control RGB LED Strip with sharp distance sensor (Read 10592 times) previous topic - next topic
Mollison92
Is that a real red, or a red LED connected to the green pin?
You need to be careful with cascaded "if"s like you have written - you may cover some ranges more than once.
Im using an RGB light strip each one to its own pin
"I live life a Quarter Mile at a Time" - Dom Torreto
Grumpy_Mike
Don't use any 'else' with the if statement and use two comparisons with an and like I said in the first reply.
Code: [Select]
if (distance < 80 ) {
    analogWrite(REDPIN, 255);
    analogWrite(GREENPIN, 0);
    analogWrite(BLUEPIN, 0);
if (distance >= 80 && distance < 150) {
    analogWrite(REDPIN, 0);
    analogWrite(GREENPIN, 255);
if (distance >= 150 && distance <230 ) {
    analogWrite(BLUEPIN, 255);
and so on, have you got the tune?
so make up the words
Mollison92
Quote
don't quite get that bit but the code i understand, so i have a 10-80cm sensor, so if i make all the values less than 80 where you have greater it should work the same??
Mollison92
Thank you so much Grumpy_Mike,
i have that working and now i can just play with distance and colour,
do you know of a way to make the sensor more accurate??
Grumpy_Mike
Quote
Sorry no, it is a miracle it is as accurate as it is.
I think you get better accuracy from an ultrasonic sensor.
Mollison92
Grumpy_Mike if I'm correct you an change accuracy like in this tutorial (http://luckylarry.co.uk/arduino-projects/arduino-using-a-sharp-ir-sensor-for-distance-calculation/)
And the data sheet for my specific sensor is (http://sharp-world.com/products/device/lineup/data/pdf/datasheet/gp2y0a21yk_e.pdf)
I modified the code in the tutorial from 65 to 27 and is what I'm using, it says something about how to decide the distance to use buy I don't understand it...
Maybe you do??
Mollison92
This code here creates a colour swirl on a loop:
Code: [Select]
  int r, g, b;
  // fade from blue to violet
  for (r = 0; r < 256; r++) {
    analogWrite(REDPIN, r);
    delay(FADESPEED);
  // fade from violet to red
  for (b = 255; b > 0; b--) {
    analogWrite(BLUEPIN, b);
    delay(FADESPEED);
  // fade from red to yellow
  for (g = 0; g < 256; g++) {
    analogWrite(GREENPIN, g);
    delay(FADESPEED);
  // fade from yellow to green
  for (r = 255; r > 0; r--) {
    delay(FADESPEED);
  // fade from green to teal
  for (b = 0; b < 256; b++) {
    delay(FADESPEED);
  // fade from teal to blue
  for (g = 255; g > 0; g--) {
    delay(FADESPEED);
is there a way that i can incorporate the changing colour into my code so as to have a colour changing blend rather than just from say 'blue to green' to more 'blue- light blue - aqua - green) depending on the height?? and also that at that height it wouldn't keep loping just change to and stop??
Grumpy_Mike
That web page is just telling you how to get a distance reading from the sensor's input. You don't want that as you are just dealing with the raw numbers so that will give you the maximum amount of distance discrimination it is possible to have. It doesn't alter the accuracy of the reading at all, all it does is put the reading into a number of centimeters. This reading is then (by necessary) much less discriminatory than the raw numbers.
Quote
Yes just fade all three colours at the same time.
Each colour can be represented by a triad, that is three numbers (red, green & blue), so you have an initial number (start colour) and a target number (end colour).
Subtract start from finish (for all three numbers), this gives you the distance or delta for each colour. Then divide this by the number of steps you want to fade with, use a floating point number here because it will almost certainly be less than one, and use that to increment the current value to write out the to each LED for each step of the fade.
Mollison92
Quote
Dont quite understand what you mean, because if i fade all three at the same time wont that just create a constant colour?? for example to make yellow is red 255 and green 255, but to make orange is like red 255 green 127, so if i faded them at the same time i couldn't make orange?
Grumpy_Mike
All three LEDs are in the fading loop but each time round the loop you add the delta value to the LED intensity. So if the red's delta value is 0.2 it only actually changes every five times round the loop. Where as is the green's delta value is 2 then it changes by two each time round the loop.
Mollison92
still don't quite understand, a bit of code may help, and also is this going to allow that say from 80 - 20 cm,  the colour will start of white and finish at red with a new colour at 5cm increments in between??
Grumpy_Mike
This is a function you can add to your code to fade from the current colour to the one passed to it.
It is not tested so may contain errors but it illustrates how to fade colours.
Code: [Select]
// set up these global variables before the setup()
int currentRed = 0, currentGreen = 0, currentBlue = 0;
void fadeTo(int R, int G, int B, int fadeSteps) {  // fade from the current colour to the one passed to the function
  float deltaR, deltaG, deltaB;
  float tempR, tempG, tempB;
// set up the temp values to the current LED state
  tempR = currentRed;
  tempG = currentGreen;
  tempB = currentBlue;
// calculate the distance between each colour as it is now, and the target colour
  deltaR = ( float(R - currentRed)) / fadeSteps;
  deltaG = ( float(G - currentGreen)) / fadeSteps;
  deltaB = ( float(B - currentBlue)) / fadeSteps;
  // fade to new colour
  for (int i = 0; i < fadeSteps; i++) {
// calculate new intermediate colour
   tempR += deltaR;
   tempG += deltaG;
   tempB += deltaB;
  // set these LEDs to the new intermediate colour
    analogWrite(REDPIN, int(tempR));
    analogWrite(GREENPIN, int(tempG));
    analogWrite(BLUEPIN, int(tempB));
    delay(FADESPEED);
  } // end of for loop
// keep the global colour up to date
  currentRed = tempR;
  currentGreen = tempG;
  currentBlue = tempB;
Mollison92
Okay, I'll give it a try, so this should all still work with my distances??
Grumpy_Mike
Quote
No it's a function to add to your sketch to allow you to fade from one colour to another. How you incorporate that into distance is up to you.
If you just use that code without trying to understand what it is doing you will not learn anything, which is the object of the exercise.
Mollison92
hmmmm, okay, i see where you coming from, its for a school project with a dead line hence asking for codes etc as i don't have time to fully write them. although as we go i am starting to work out and understand a bit more.
do you know of a way i can incorporate the colour change into my distances, or am i better of with just going to a colour wheel and finding the number values for each colour i wan't and go that way??
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
