Topic: Two wire hall effect gear sensor (Read 7240 times) previous topic - next topic
EmilyJane
Quote
If it was me, I would just buy a Allegro version that uses voltage output:
That's what I would suggest or maybe the ATS627 if you need it to work below 10Hz.
mgandalf
At the risk of sounding stupid, how can I tell which are current output and which are voltage?
Thanks, Mark.
retrolefty
Thanks, Mark.
By careful reading of the datasheet. But the term 'two wire' is kind of a process control world 'buzz word' for current loop devices. Most sensors used in process plants use current loop sensors because it allows for long cable runs between the sensors and the control system that won't be effected by the length of cabling causing voltage drops that would effect accuracy.
Lefty
EmilyJane
A quick test is if it has three or more leads, it's probably a voltage out. Otherwise you would have to take a close look ate the data sheet. Both the parts that Lefty and I suggested are voltage out.
mgandalf
Great stuff, thanks! I'll try the latter one suggested. I'm attempting to sense the rotation of a carousel within a jukebox.
- Mark.
