Loading...
Pages: 1 [2]   Go Down
Author Topic: AD595AQ for Car Exhaust Gas Temperature  (Read 1541 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
I have substituted them with one another the same thing.
Arduino uses the same L7809CV chip as the AD595AQ, and the L7809CV is connected to the chassis.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
By the "same thing" do you mean they both read wrong now or that just the one on the car reads wrong. What happens when you touch the "home" one to the car.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
They both read wrong.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
Oh, okay. Something happened to your circuit in transit apparently. You need to thoroughly check it for loose, broken wires, short circuits, etc. Anything that is different from when it last worked correctly.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
It works fine when I don't connect it to the car, so the probe that's on the car, when removed and pin 1 connected to pin 4 it works fine!
So the chip is fine, isn't it?
Is it better to go and get an ungrounded probe then? And leave the circuit with pin 1 connected to pin 4?
Thanks.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
You could try that. Otherwise it's a mystery to me.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
By the way, why did you choose to run it off 9V? That part works on 5V.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
I needed temperature of more than 300'C so I increased the input voltage.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
Ah, of course. Did you consider this part? http://www.sparkfun.com/products/307
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
No I haven't, but does that solve my grounding problem?
Thanks.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
Quote
No, only in the sense that it might correct the problem that we haven't been able to sleuth out yet. Plus I just like the fact that it has a digital interface so it leaves out some steps in processing the data.
Without looking at your project, I'm at a standstill. Can you post the EXACT schematic diagram and some closeup photos of all sides of your physical circuit?
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
I got an ungrounded thermocouple and everything is working normally now.
Thanks for all the help.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
Good deal!
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
