Topic: A strange 16 X 1 (Read 2153 times) previous topic - next topic
Techone
Hi guys;
I have this display that I bought for $2 can at a surplus store. It look like a 16 X 1. No datasheet ( I try to find it ) So I find a datasheet of a different display ( parallel type ) and maybe the pinout are standard ? Ok, I look at this tutorial to how to connect a LCD - parallel type http://www.ladyada.net/learn/lcd/charlcd.html   Guess what ?  IT WORK !! But not realy. I saw "Hello World" and the seconds. Hello word was cut off, and the second start next to it.  ???  Mmm ??? So I modify the program "Hello World" and here the code and a picture. It work better in this mode. I just don't want to throw away this LCD. I guess I will not.
Code: [Select]
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd( 7, 8, 9, 10, 11, 12);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("12345789");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print("12345678");
liuzengqiang
I think 16X1 display organizes it memory like a 8X2 display so the first 8 characters are line 1 and the next 8 are line 2.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Techone
Humm... That will explain. So therefore when I use this LCD, I have to bear in mind "this" feature during programing and display info / data. Well at least, it was a twonnie well spend. ( the $ 2 coin canadian term )
liuzengqiang
$2 yes, definitely good buy. If you need to display more info, go for a 16X2 or 20X4 display. Here is a couple of shields I designed just in case you're interested;)
http://www.inmojo.com/store/liudr-arduino-and-physics-gadgets/item/phi-2-interactive-arduino-shield-2004/
http://www.inmojo.com/store/liudr-arduino-and-physics-gadgets/item/phi-2-interactive-shield-for-arduino/
floresta
#4
Jul 30, 2011, 02:15 am Last Edit: Jul 30, 2011, 02:17 am by floresta Reason: 1
Quote
Not all 16x1 displays, just the vast majority of them.
This is why I find it so incredibly unusual to have the LiquidCrystal library default to a "1-line" configuration if the lcd.begin statement is left out.  Virtually every display in use by Arduinoists requires a "2-line" configuration, including most of the 16x1 displays.  For more information about this follow the LCD Addressing link at http://web.alfredstate.edu/weimandn.
Don
Techone
@liudr
Thanks for the link. Impressive work. I have already 3 16X2 and 1 20X2. <--- I need a new heathers, not the one who fit the breadboard but smaller one. I don't know where to get it ..and some "adapter" to fit into 0.1.
@floresta
Thank for the link about the LCD addressing. I will read it.
liuzengqiang
What parts do you want to fit the headers on? (did you mean header?)
Techone
liudr, here a picture of what I am talking about. The 20X2 is the top ( small, don't fit the standard header. The bottom is the standard header. So I will like to use the 20X2 display. Not shoving wires into the header.
liuzengqiang
Measure the distance between the two farthest holes and see if you get 38mm. From the picture I suspect it is 2mm spacing.
Techone
Yes. The top one is 2mm and the bottom is larger. I know they don't fit so where can I find 2mm header and "adapter" to fit a breadboard ? Because the 2mm don't fit the breadboard.
liuzengqiang
I wish I knew a part. tried googling 2mm 1" adapter and the first few hits don't seem to help much.
Can't you just use jumper wires like these?
http://www.pololu.com/catalog/category/68
or
http://dipmicro.com/store/ZY-800
Techone
Well I will use wires to connect with that display ( 20X2 ) for the mean time. I will have to build an adapter to fit a breadboard.
Thank liudr for your help. You are LCD guy.  ;)
liuzengqiang
You're welcome. There are a few of us LCD guys/gals.
