Loading...
Pages: [1]   Go Down
Author Topic: 2803 vs 2003 for Transistor Array  (Read 328 times)
Victoria, BC, Canada
Offline Offline
Full Member
View Profile
WWW
I have a board (a design of Ladyada's I believe) which uses a 2003 chip with 7 darlingtons to control a stepper motor
While looking around, I found a 2803 that seems quite similar internally (diff outside of course).
My question - could I create a board using the 2803 to replace the 2003? Or is there some internal detail I'm overlooking?
I'm asking because the 2803 has 8 darlingtons, which would let me control two stepper motors with one chip, instead of using two 2003s, and wasting 6 outputs.
Logged
Offline Offline
Full Member
View Profile
WWW
Here are the two data sheets if they would be of help:
2803:
http://www.taydaelectronics.com/datasheets/A-067.pdf
2003:
http://www.taydaelectronics.com/datasheets/A-070.pdf
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
If you look in the datasheets you'll see they are basically the same.   In fact the clue is in the part number   2803 and 2003 differ by an '8' - because its an 8-channel version - well that's likely to be the intention.
In the early days of ICs 18 pin packages didn't exist I believe, only 8,14,16,20,24,28,40 etc, hence the awkward restriction of the original chips to 7 channels.
Logged
Pages: [1]   Go Up
Print
Jump to:
