Topic: LSM303 problem (Read 2545 times) previous topic - next topic
daddym85
I am using the LSM303DLH board from pololu, I am working on an arduino uno and I have connected the sensor in the following way:
                   Uno      LSM303DLH
                    5V  ->  VIN
                   GND  ->  GND
          Analog Pin 5  ->  SCL
          Analog Pin 4  ->  SDA
The library https://github.com/ryantm/LSM303DLH doesn't work for me, I can't interface the sensor by using the Wire library because my arduino freezes at Wire.beginTrasmission().
Any idea?
Does this breakout board work at 5V or at 3.3V?
Thanks.
johnwasser
The I2C bus requires pull-up resistors on both lines.  If the breakout board doesn't have them you have to provide them.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
btsp
#2
Jul 29, 2011, 09:28 pm Last Edit: Jul 29, 2011, 09:31 pm by btsp Reason: 1
the board has the pullup resistors.
Is it hanging  when you call the enable function?
I supply 3.3V to it haven't tried the 5V
johnwasser
If your code isn't working you might get better advice if you posted your code.
They say the Vin line will take 2.6V to 5.5v and there are two regulators to provide 3.0V VDD and 1.8V VIO.  The chip requires 2.5V to 3.3V for VDD and is run off the 3.0V regulator.  I guess if you give it 2.6V for Vin you can get 2.5V out of the regulator.
daddym85
Yes, my arduino is hanging when I call the enable function. It freezes at Wire.beginTrasmission.
My code comes from the example:
#include <Wire.h>
#include <LSM303DLH.h>
LSM303DLH compass;
  Wire.begin();
  compass.enable();
  compass.read();
  Serial.print("A ");
  Serial.print("X: ");
  Serial.print(compass.a.x);
  Serial.print(" Y: ");
  Serial.print(compass.a.y);
  Serial.print(" Z: ");
  Serial.print(compass.a.z);
  Serial.print(" M ");
  Serial.print(compass.m.x);
  Serial.print(compass.m.y);
  Serial.println(compass.m.z);
  delay(100);
void LSM303DLH::enable(void)
   //Enable Accelerometer
   Wire.beginTransmission(ACC_ADDRESS);
   Wire.send(CTRL_REG1_A);
   //0x27 = 0b00100111
   // Normal power mode, all axes enabled
   Wire.send(0x27);
   Wire.endTransmission();
   //Enable Magnetometer
   Wire.beginTransmission(MAG_ADDRESS);
   Wire.send(MR_REG_M);
   //0x00 = 0b00000000
   // Continuous conversion mode
   Wire.send(0x00);
Can I try to supply 3.3V?
btsp
i am assuming the
function is in the LIB. and you are not putting it in the code?
but try supply the 3.3 volts to it and let me know how that goes.
daddym85
Yes, the void LSM303DLH::enable(void) function is only in the library
btsp
you tried using 3.3v?
daddym85
Yes, I have connected VIN to 3.3v but my code doesn't work.
Any idea?
Thanks.
csed18
                   Uno      LSM303DLH
                    5V  ->  VIN
                   GND  ->  GND
          Analog Pin 5  ->  SCL
          Analog Pin 4  ->  SDA
Any idea?
Thanks.
I have the same problem , do you solve it??
