Topic: DDS Library for The AD9835 (Read 5220 times) previous topic - next topic
LachlanGunn
Hello.  Having bought one of the AD9835 breakout boards from Sparkfun (http://www.sparkfun.com/products/9169), the lack of a library to control it was rather noticable.  As a result, I have decided to write one, called Synthesis.
URL: https://github.com/LachlanGunn/Synthesis
The intention is for this library to add support for other devices as I acquire them.  API documentation is included in the library.
Usage Example:
Code: [Select]
* Fixed-frequency sinusoid generator.
* This example produces a 1MHz sinusoidal signal using the AD9835 class
* from the Synthesis library.
#include <SPI.h>
#include "AD9835.h"
// We begin by creating the AD9835 object with the pin assignments
// that are used.  If another pinout is used, this must be
// modified.
AD9835 dds(
        7, // FSYNC
        3, // SCLK
        2, // SDATA
        6, // FSEL
        5, // PSEL1
        4, // PSEL0
        50000000 // hzMasterClockFrequency (50MHz)
    // We must first set up all of our output pins.
    dds.begin();
    // We then set the board to produce a 1MHz signal.
    dds.setFrequencyHz(0, 1000000);
    dds.selectFrequencyRegister(0);
    // Without modulation the choice of phase offset does not matter,
    // but we set it to zero for good measure.
    dds.setPhaseDeg(0,0);
    dds.selectPhaseRegister(0);
    // Finally, we turn on the IC.
    dds.enable();
    while(1)
        delay(10);
