Topic: SENSOR PING))) QUESTION (Read 2873 times) previous topic - next topic
Muneeb
I GOT A PING))) SENSOR YESTERDAY
NOW I KNOW HOW DOES IT WORK
BUT I NOW, I NEED TO KNOW WHAT SHOULD I DO, TO TURN ON AN LED OR MOTOR WHEN THE SENSOR REACHES IN THE MIDDLE OF TWO NUMBERS.
WHAT SHOULD I CHANGE IN THE CODE
IF YOU DONT REALLY UNDERSTAND WHAT I MEAN, POST A COMMENT
lesto
Unoffical Telegram group https://telegram.me/joinchat/ALRu8ACkdTdXyz-2P7v13A
Muneeb
/* Ping))) Sensor
   This sketch reads a PING))) ultrasonic rangefinder and returns the
   distance to the closest object in range. To do this, it sends a pulse
   to the sensor to initiate a reading, then listens for a pulse
   to return.  The length of the returning pulse is proportional to
   the distance of the object from the sensor.
   The circuit:
    * +V connection of the PING))) attached to +5V
    * GND connection of the PING))) attached to ground
    * SIG connection of the PING))) attached to digital pin 7
   http://www.arduino.cc/en/Tutorial/Ping
   created 3 Nov 2008
   by David A. Mellis
   modified 30 Jun 2009
   by Tom Igoe
   This example code is in the public domain.
// this constant won't change.  It's the pin number
// of the sensor's output:
const int pingPin = 7;
  // initialize serial communication:
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, inches, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  Serial.print(inches);
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
  Serial.println();
  delay(100);
long microsecondsToInches(long microseconds)
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second).  This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
lesto
if (cm > minDistance && cm < maxDistance){
//turn led on
AWOL
@OP: Please don't shout, and when posting code, use the # icon on the toolbar to put the code into a code box.
Muneeb
but can you put this somewhere on the code and post it so its gonna be easy for me to understand
and then i will try it
lesto
it's easy, and i won't code for you, unless you pay me :smiley-mr-green:
Muneeb
because im a 13 years old beginner.
and i really need help so that i will be able to make a robot.
and can a little part of code can be moved anywhere else and will it still work?  :smiley-eek-blue:
Muneeb
ok, it's not working because of the cm or inche. :0
is there something else that can replace the cm or inche    :smiley-slim:
AWOL
Furlongs? What you have written doesn't make sense. Could you tell us what you think the problem is?
Muneeb
i think the problem is that my arduino uno cant read the cm and inches.i just need help for something that can replace the cm and inches
what i have written is:
/* Ping))) Sensor
   The circuit:
   created 3 Nov 2008
   by David A. Mellis
   by Tom Igoe
  pinMode (13,OUTPUT);
  Serial.print(cm);
  Serial.print("cm");
  Serial.println();
  delay(100);
  if ( pingPin,_______________ )
    digitalWrite(13,HIGH);
    digitalWrite(13,LOW);
AWOL
Please back to your last post,click on "modify", then highlight the code, then click on the # icon on the editor's toolbar.
Then click on "save".
Well of course it can't.
Muneeb
#12
Jul 31, 2011, 09:16 pm Last Edit: Jul 31, 2011, 09:46 pm by Muneeb Reason: 1
/* Ping))) Sensor
   The circuit:
   created 3 Nov 2008
   by David A. Mellis
   by Tom Igoe
  Serial.print(cm);
  Serial.print("cm");
  Serial.println();
  delay(100);
Muneeb
#13
Jul 31, 2011, 09:17 pm Last Edit: Jul 31, 2011, 09:48 pm by Muneeb Reason: 1
doned
AWOL
#14
Jul 31, 2011, 09:23 pm Last Edit: Jul 31, 2011, 09:24 pm by AWOL Reason: 1
No, not the "quote" icon, the Code (#) icon.
You can go back and modify old posts.
Why do you think that?
