Loading...
Pages: [1]   Go Down
Author Topic: Ethernet Shield (W5100) recieves weird data  (Read 829 times)
Offline Offline
Newbie
View Profile
i tried the Webclient example with the Ethernet Shield v2 and sometimes I get readable data but most of the time not:
Code:
connecting...
connected
Y©FIªx“ä«Å(û ü_Fv8tŒî´!SœùùòÃ6éK‘“c
disconnecting.
connecting...
connected
[ìe.timers={};window.google.startTick=function(a,b){i[a]={t:{start:(new Date).getTime()},bfr:!(!b)}};window.google.tick=function(a,b,c){if(!i[a])google.startTick(a);i[a].t[b]=c||(new Date).getTime()};google.sta{}};
window.google.sn="webhp";var i=window.google.timers={};window.google.startTick=function(a,b){i[a]={t:{start:(new Date).getTime()},bfr:!(!b)}};window.google.tick=function(a,b,c){if(!i[a])google.startTick(a);i[a].t[b]=c||(new Date).getTime()};google.sta{}};
disconnecting.
connecting...
connected
ȁ×,|øXW ¦‹ÂÉéHQ­üŽq×fæ¡ùÍíe\@Ð ö˃ß
FP¢
disconnecting.
connecting...
connected
[¨a
</PRE>
zu verarbeiten, trat der folgende F
disconnecting.
connecting...
connected
STRONG>Ung&uuml;ltige Anfrage</STRONG>
</UL>
disconnecting.
Here's the code:
Code:
  Web client
 This sketch connects to a website (http://www.google.com)
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 created 18 Dec 2009
 by David A. Mellis
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192,168,2,177 };
byte server[] = { 74,125,39,147 }; // Google
byte gateway[] = { 192,168,2, 1 };
byte subnet[] = { 255, 255, 255, 0 };
Client client(server, 80);
  // start the Ethernet connection:
  Ethernet.begin(mac, ip, gateway, subnet);
  // start the serial library:
  // give the Ethernet shield a second to initialize:
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect()) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println("GET / HTTP/1.0");
    client.println();
  else {
    // kf you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    for(;;)
Could someone try the code and tell me if the results are the same?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Try the below code to see if you get something readable.
Code:
//zoomkat 11-13-10
//simple ethernet client test code
//for use with IDE 0021 and W5100 ethernet shield
//modify the arduino lan ip address as needed
//open serial monitor to see what the arduino receives
//push the shield reset button to run client again
#include <SPI.h>
byte ip[] = { 192, 168, 1, 102 }; // Arduino IP address
byte server[] = { 208, 104, 2, 86 }; // zoomkat's web site
  Ethernet.begin(mac, ip);
  Serial.println("starting simple arduino client test");
    client.println("GET /~shb/arduino.txt HTTP/1.0");
    client.println();
    Serial.print(c);
    Serial.println("==================================");
    Serial.println("");
    client.stop();
    for(;;);
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
Thanks for your reply. I tried your code but I'm still getting no right output:
Code:
connecting...
connected
ÎF]f:
<UL>
disconnecting.
connecting...
connected
r au, trat de
disconnecting.
connecting...
connected
iten:
<UL>
<L
disconnecting.
connecting...
connected
 auf´ ÉH2yÏ4P
disconnecting.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Just as a point of reference, below is what ia returned to my serial monitor when I run the code I posted.
connecting...
connected
HTTP/1.1 200 OK
Date: Sun, 31 Jul 2011 17:16:48 GMT
Server: Apache
Last-Modified: Sat, 13 Nov 2010 16:31:40 GMT
Accept-Ranges: bytes
Content-Length: 51
Connection: close
Content-Type: text/plain; charset=UTF-8
Woohoo! Your arduino ethernet client works!
zoomkat
disconnecting.
Logged
Offline Offline
Newbie
View Profile
Today I tried the same on my windows machine and everythink just works fine ... Seems to be a Fedora issue, maybe the compiler or a bug in the ethernet library.
Any idea where I can report this or how to explore the issue to get it fixed?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
Fedora forum?
Logged
Pages: [1]   Go Up
Print
Jump to:
