Topic: having a little trouble please help (Read 3897 times) previous topic - next topic
nk3495
Jul 30, 2011, 09:04 pm Last Edit: Jul 30, 2011, 10:06 pm by nk3495 Reason: 1
I'm trying to make an up down counter it counts up each time you press one button and i want it to count down when you press the other. i have it counting up but don't know what to do to get it to count down ? hope someone can help
here is my code
Code: [Select]
int a=2;
int b=3;
int c=4;
int d=5;
int e=6;
int f=7;
int g=8;
int number=0;
int pin9=9;
int pin10=10;
int pin12=12;
int tens=0;
int unit=0;
int digit=0;
int tens1=0;
int presentvalue=0;
int previousvalue=0;
// Pins for A B C D E F G, in sequence
const int segs[7] = { 2, 3, 4, 5, 6, 7, 8, };
// Segments that make each number
const byte numbers[10] = { 0b1000000, 0b1111001, 0b0100100, 0b0110000, 0b0011001, 0b0010010,
0b0000010, 0b1111000, 0b0000000, 0b0010000 };
//Serial.begin(9600);
pinMode(a,OUTPUT);
pinMode(b,OUTPUT);
pinMode(c,OUTPUT);
pinMode(d,OUTPUT);
pinMode(e,OUTPUT);
pinMode(f,OUTPUT);
pinMode(g,OUTPUT);
pinMode(pin9,OUTPUT);
pinMode(pin10,OUTPUT);
pinMode(pin12,INPUT);
zero();
presentvalue=digitalRead(pin12);
if (presentvalue!=previousvalue)
if (presentvalue==1)
{number=number+1;}
previousvalue=presentvalue;
display1();
void display1()
tens1=number%100;
tens=tens1/10;
unit=tens1%10;
for (int i=0;i<=10;i++)
 digit=tens;
 digitselection();
 digitalWrite(pin9,HIGH);
 digitalWrite(pin10,LOW);
 delay(1);
 digit=unit;
 digitselection();
 digitalWrite(pin9,LOW);
 digitalWrite(pin10,HIGH);
 delay(1);
if (number>99) {number=0;}
void zero()
digitalWrite(a,LOW);
digitalWrite(b,LOW);
digitalWrite(c,LOW);
digitalWrite(d,LOW);
digitalWrite(e,LOW);
digitalWrite(f,LOW);
digitalWrite(g,HIGH);
void one()
digitalWrite(a,HIGH);
digitalWrite(d,HIGH);
digitalWrite(e,HIGH);
digitalWrite(f,HIGH);
void two()
digitalWrite(c,HIGH);
digitalWrite(g,LOW);
void three()
void four()
void five()
digitalWrite(b,HIGH);
void six()
void seven()
void eight()
void nine()
void digitselection()
 switch (digit)
   case 0:
   zero();
   case 1:
   one();
   case 2:
   two();
   case 3:
   three();
   case 4:
   four();
   case 5:
   five();
   case 6:
   six();
   case 7:
   seven();
   case 8:
   eight();
   case 9:
   nine();
robtillaart
please modify your post, select the code and press the # button .. makes the code look better , thank you.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Grumpy_Mike
You need to repeat the code in this section:-
Code: [Select]
{number=number+1;}
Using different variables to handle the down button, changing of course
{number=number+1;}
to
{number=number-1;}
robtillaart
#3
Jul 30, 2011, 10:17 pm Last Edit: Jul 30, 2011, 10:27 pm by robtillaart Reason: 1
First have a look at arrays, it can make your code much shorter !!
* add  pin11 in input mode  (you know how to do this, please use meaningfull names like up and DOWN :)
* add  int step = 1;   (you know how to do this)
* change loop.
Code: [Select]
 // READ INPUT
 if (digitalRead(pinDown) == LOW) step = -1;
 if (digitalRead(pinUp) == LOW) step = +1;
 // ADJUST NUMBER
 number += step;
 number = constrain(number, 0, 100);  // optional
 // DISPLAY IT
 display1();
Rob Tillaart
robtillaart
wrt the array's
Code: [Select]
int a=2;
int b=3;
int c=4;
int d=5;
int e=6;
int f=7;
int g=8;
could be
int segment[7] = {2,3,4,5,6,7,8 };
and that allows you todo
Code: [Select]
for (byte i=0; i< 7; i++) pinMode(segment[i]. OUTPUT);
and it can change
Code: [Select]
void zero()
void nine()
to a single function:
Code: [Select]
void digit(int nr)
  for (byte i=0; i<7; i++)
    digitalWrite(segment[i], bitRead(numbers[nr], i);
call to zero() should be replaced by a call to digit(0);  etc
Success,
Rob
Rob Tillaart
robtillaart
In a modded version you can change
Code: [Select]
// READ INPUT
into
Code: [Select]
// READ INPUT
  if (digitalRead(pinDown) == LOW) step--;
  if (digitalRead(pinUp) == LOW) step++;
This makes the counting faster and slower, upper and downer ;)
Rob Tillaart
nk3495
#6
Jul 30, 2011, 11:13 pm Last Edit: Jul 30, 2011, 11:18 pm by nk3495 Reason: 1
now i'm getting several errors what did i do wrong?
error: 'step' was not declared in this scope?
new code
Code: [Select]
int a=2;
int b=3;
int c=4;
int d=5;
int e=6;
int f=7;
int g=8;
int number=0;
int pin9=9;
int pin10=10;
int pinUp=11;
int pinDown=12;
int tens=0;
int unit=0;
int digit=0;
int tens1=0;
int increment=1;
pinMode(a,OUTPUT);
pinMode(b,OUTPUT);
pinMode(c,OUTPUT);
pinMode(d,OUTPUT);
pinMode(e,OUTPUT);
pinMode(f,OUTPUT);
pinMode(g,OUTPUT);
pinMode(pinUp,INPUT);
pinMode(pinDown,INPUT);
zero();
 //READ INPUT
 if (digitalRead(pinDown)== LOW) step =-1;
 if (digitalRead(pinUp) == LOW) step =1
 //ADJUST NUMBER
 number += step;
 number = consteian(number, 0 , 100);  //
void display1()
tens1=number%100;
tens=tens1/10;
unit=tens1%10;
 digit=tens;
 digitselection();
 delay(1);
 digit=unit;
 digitselection();
 delay(1);
void zero()
void one()
void two()
void three()
void four()
void five()
void six()
void seven()
void eight()
void nine()
 switch (digit)
   case 0:
   zero();
   case 1:
   one();
   case 2:
   two();
   case 3:
   three();
   case 4:
   four();
   case 5:
   five();
   case 6:
   six();
   case 7:
   seven();
   case 8:
   eight();
   case 9:
   nine();
Grumpy_Mike
Read the compile errors and correct them:-
1) step appears to be a reserved word use mystep instead and define it as an int at the start.
2) Check for missing ; for the next error in the line above
3) what is this:- number = consteian(number, 0 , 100);  there is no function called consteian
4) You missed a } after this call
Then it compiles.
nk3495
#8
Jul 30, 2011, 11:28 pm Last Edit: Jul 30, 2011, 11:33 pm by nk3495 Reason: 1
that was constrain not constreian mybad
after your fixes im getting 3 errors at void display1()  {
cpp; in function 'void loop()':
63;error; a function-defintion is not allowed here before '{' token
232; error; expected '}' at end of input
?? thanks
heres the code if you need it
Code: [Select]
int a=2;
int b=3;
int c=4;
int d=5;
int e=6;
int f=7;
int g=8;
int number=0;
int pin9=9;
int pin10=10;
int pinUp=11;
int pinDown=12;
int tens=0;
int unit=0;
int digit=0;
int tens1=0;
int increment=1;
int mystep=0;
pinMode(a,OUTPUT);
pinMode(b,OUTPUT);
pinMode(c,OUTPUT);
pinMode(d,OUTPUT);
pinMode(e,OUTPUT);
pinMode(f,OUTPUT);
pinMode(g,OUTPUT);
zero();
  //READ INPUT
  if (digitalRead(pinDown) == LOW) mystep = -1;
  if (digitalRead(pinUp) == LOW) mystep = +1;
  //ADJUST NUMBER
  number += mystep;
  number = constrain(number, 0 , 100);  //
  // DISPLAY IT
  display1();
void display1()
tens1=number%100;
tens=tens1/10;
unit=tens1%10;
  digit=tens;
  digitselection();
  delay(1);
  digit=unit;
  digitselection();
  delay(1);
void zero()
void one()
void two()
void three()
void four()
void five()
void six()
void seven()
void eight()
void nine()
  switch (digit)
    case 0:
    zero();
    case 1:
    one();
    case 2:
    two();
    case 3:
    three();
    case 4:
    four();
    case 5:
    five();
    case 6:
    six();
    case 7:
    seven();
    case 8:
    eight();
    case 9:
    nine();
robtillaart
add 1) step is auto-highlighted but you can use it if you declare it. But increment might be a better name
add 3) number = consteian(number, 0 , 100);  ==>  number = constrain(number, 0 , 100);
Rob Tillaart
robtillaart
#brackets in loop is incorrect  check this one...
Code: [Select]
  //READ INPUT
  //ADJUST NUMBER
  number += mystep;
  // DISPLAY IT
  display1();
Rob Tillaart
nk3495
#11
Jul 30, 2011, 11:42 pm Last Edit: Jul 30, 2011, 11:52 pm by nk3495 Reason: 1
it doesnt count up or down when i press the button it jst runs?
i wanted it so everytime i press the up button it counts up & the down button it counts down not continously
Grumpy_Mike
How are the buttons wired up? Do you need to enable the internal pull ups?
That code will count very fast until it hits the limit, in fact it will count even when the buttons are not pressed, all the presses are doing are changing the direction of the count.
Why did you not do what I said earlier?
nk3495
if you are talking about shorting the code? its because i want to get this straightened out first. if thats what your talking about
the buttons are wired like this the input wire for pins 11 &12 both go to there own 10k resistor & 1 side of the switch then the other side of the resistor goes to gnd
the code i put at the beginning of this post counted up everytime i hit the button & all i wanted to know was how to add another button to count down everytime i hit it not for it to continuously count
robtillaart
Code: [Select]
  mystep = 0;  // don't count if no butt on pressed
  //READ INPUT
  //ADJUST NUMBER
  number += mystep;
  // DISPLAY IT
  display1();
Rob Tillaart
