Offline
Newbie
« Reply #15 on: July 30, 2011, 05:15:37 pm » |
ok that works one more think though how would i get it to not bounce (go one at a time each way) ?
Logged
Manchester (England England)
Online
Brattain Member
Solder is electric glue
« Reply #16 on: July 30, 2011, 05:20:13 pm » |
No look at my reply, the bit about remembering the previous state of the button and only incrementing or decrementing when the state changes from unpressed to pressed. To debounce just add a delay after you detect a change.
« Last Edit: August 02, 2011, 06:11:59 am by Grumpy_Mike »
Logged
Offline
Newbie
« Reply #17 on: August 01, 2011, 07:57:46 pm » |
if i put a delay after the change it make the two displays kinda pulse what else can i do so it does not bounce? thanks again for your help
Logged
Online
Brattain Member
« Reply #18 on: August 02, 2011, 06:13:43 am » |
if i put a delay after the change it make the two displays kinda pulse Yes that is because you are not REMEMBERING the state of the buttons from one loop to the next. It is not bounce you are seeing but the fact that you have inadequacy code. Post what you have so far.
Logged
Offline
Newbie
« Reply #19 on: August 02, 2011, 02:45:11 pm » |
it does bounce though. with no delay add and with one add it pulses! heres what i got. int a=2; int b=3; int c=4; int d=5; int e=6; int f=7; int g=8; int number=0; int pin9=9; int pin10=10; int pindown=11; int pinup=12; int tens=0; int unit=0; int digit=0; int tens1=0; int presentvalue=0; int previousvalue=0;
// Pins for A B C D E F G, in sequence const int segs[7] = { 2, 3, 4, 5, 6, 7, 8, };
// Segments that make each number const byte numbers[10] = { 0b1000000, 0b1111001, 0b0100100, 0b0110000, 0b0011001, 0b0010010, 0b0000010, 0b1111000, 0b0000000, 0b0010000 };
void setup() { //Serial.begin(9600); pinMode(a,OUTPUT); pinMode(b,OUTPUT); pinMode(c,OUTPUT); pinMode(d,OUTPUT); pinMode(e,OUTPUT); pinMode(f,OUTPUT); pinMode(g,OUTPUT); pinMode(pin9,OUTPUT); pinMode(pin10,OUTPUT); pinMode(pindown,INPUT); pinMode(pinup,INPUT); zero(); }
void loop() { presentvalue=digitalRead(pinup); if (presentvalue!=previousvalue) { if (presentvalue==1) {number=number+1;} previousvalue=presentvalue; }
presentvalue=digitalRead(pindown); if (presentvalue!=previousvalue) { if (presentvalue==1) {number=number-1;} previousvalue=presentvalue;
} display1(); } void display1() { tens1=number%100; tens=tens1/10; unit=tens1%10; for (int i=0;i<=10;i++) { digit=tens; digitselection(); digitalWrite(pin9,HIGH); digitalWrite(pin10,LOW); delay(1); digit=unit; digitselection(); digitalWrite(pin9,LOW); digitalWrite(pin10,HIGH); delay(1); } if (number>99) {number=0;} }
void zero() { digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); digitalWrite(e,LOW); digitalWrite(f,LOW); digitalWrite(g,HIGH); }
void one() { digitalWrite(a,HIGH); digitalWrite(d,HIGH); digitalWrite(e,HIGH); digitalWrite(f,HIGH); digitalWrite(g,HIGH); digitalWrite(b,LOW); digitalWrite(c,LOW); }
void two() { digitalWrite(c,HIGH); digitalWrite(f,HIGH); digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(g,LOW); digitalWrite(e,LOW); digitalWrite(d,LOW); }
void three() { digitalWrite(e,HIGH); digitalWrite(f,HIGH); digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(g,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); }
void four() { digitalWrite(a,HIGH); digitalWrite(d,HIGH); digitalWrite(e,HIGH); digitalWrite(b,LOW); digitalWrite(c,LOW); digitalWrite(f,LOW); digitalWrite(g,LOW); }
void five() { digitalWrite(e,HIGH); digitalWrite(b,HIGH); digitalWrite(a,LOW); digitalWrite(f,LOW); digitalWrite(g,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); }
void six() { digitalWrite(a,HIGH); digitalWrite(b,HIGH); digitalWrite(f,LOW); digitalWrite(g,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); digitalWrite(e,LOW); }
void seven() { digitalWrite(d,HIGH); digitalWrite(e,HIGH); digitalWrite(f,HIGH); digitalWrite(g,HIGH); digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(c,LOW); }
void eight() { digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); digitalWrite(e,LOW); digitalWrite(f,LOW); digitalWrite(g,LOW); }
void nine() { digitalWrite(d,HIGH); digitalWrite(e,HIGH); digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(c,LOW); digitalWrite(f,LOW); digitalWrite(g,LOW); }
void digitselection() { switch (digit) { case 0: zero(); break; case 1: one(); break; case 2: two(); break; case 3: three(); break; case 4: four(); break; case 5: five(); break; case 6: six(); break; case 7: seven(); break; case 8: eight(); break; case 9: nine(); break; } }
Logged
Online
Brattain Member
« Reply #20 on: August 02, 2011, 02:55:01 pm » |
This was because you were using the same previous value variable for both the up and down button. Try this:- int a=2; int b=3; int c=4; int d=5; int e=6; int f=7; int g=8; int number=0; int pin9=9; int pin10=10; int pindown=11; int pinup=12; int tens=0; int unit=0; int digit=0; int tens1=0; int presentvalueUp=0, presentvalueDown=0 ; int previousvalueUp=0, previousvalueDown=0;
void loop() { presentvalueUp=digitalRead(pinup); if (presentvalueUp != previousvalueUp && presentvalueUp == LOW) // do it only on the falling edge of the input { number=number+1; previousvalueUp=presentvalueUp; delay(20); // debounce delay }
presentvalueDown=digitalRead(pindown); if (presentvalueDown != previousvalueDown && presentvalueDown == LOW) // do it only on the falling edge of the input { number=number-1; previousvalueDown = presentvalueDown; delay(20); // debounce delay } display1(); } void display1() { tens1=number%100; tens=tens1/10; unit=tens1%10; for (int i=0;i<=10;i++) { digit=tens; digitselection(); digitalWrite(pin9,HIGH); digitalWrite(pin10,LOW); delay(1); digit=unit; digitselection(); digitalWrite(pin9,LOW); digitalWrite(pin10,HIGH); delay(1); } if (number>99) {number=0;} }
Logged
Offline
Newbie
« Reply #21 on: August 02, 2011, 03:06:41 pm » |
it doesn't count when i press the button?
Logged
Online
Brattain Member
« Reply #22 on: August 02, 2011, 03:08:34 pm » |
How have you got the buttons wired up? Do you have a low on a press?
Logged
Online
Brattain Member
« Reply #23 on: August 02, 2011, 03:10:46 pm » |
Sorry try this:- int a=2; int b=3; int c=4; int d=5; int e=6; int f=7; int g=8; int number=0; int pin9=9; int pin10=10; int pindown=11; int pinup=12; int tens=0; int unit=0; int digit=0; int tens1=0; int presentvalueUp=0, presentvalueDown=0 ; int previousvalueUp=0, previousvalueDown=0;
void loop() { presentvalueUp=digitalRead(pinup); if (presentvalueUp != previousvalueUp && presentvalueUp == LOW) // do it only on the falling edge of the input { number=number+1; delay(20); // debounce delay } previousvalueUp=presentvalueUp;
presentvalueDown=digitalRead(pindown); if (presentvalueDown != previousvalueDown && presentvalueDown == LOW) // do it only on the falling edge of the input { number=number-1; delay(20); // debounce delay } previousvalueDown = presentvalueDown; display1(); } void display1() { tens1=number%100; tens=tens1/10; unit=tens1%10; for (int i=0;i<=10;i++) { digit=tens; digitselection(); digitalWrite(pin9,HIGH); digitalWrite(pin10,LOW); delay(1); digit=unit; digitselection(); digitalWrite(pin9,LOW); digitalWrite(pin10,HIGH); delay(1); } if (number>99) {number=0;} }
Logged
Offline
Newbie
« Reply #24 on: August 02, 2011, 03:47:04 pm » |
much better thank you so much for your help just so you know the button take a high not a low but i fixed that myself thanks again!
Logged
