Topic: i2c and SPI together (Read 3606 times) previous topic - next topic
gknight4
I've looked around these boards, and darned if I can see if anyone has been able to implement SPI and I2C (master) in the same sketch.
What I find is that as soon as I run SPI.begin();, I2c stops responding.
As a matter of fact, if I just set digital pin 11 to output - DDRB=40 ; - it kills I2C. In other words DDRB=32 ; (digital pin 13 is output) and I2C is fine. DDRB=40 ; (digital pins 13 and 11 are output) and I2C is dead.
Why would the IO status of pin 11 have anything to do with I2C?!
At the moment, I'm working to redo the necessary functionality of Wire until I either A) discover what the problem with Wire is, and fix it, or B) redo it myself.
So, who else has SPI and I2C working side-by-side? Thanks!
Thumbs Up!
Gene Knight
CrossRoads
Anyone using the adafruit RTC/SD shield would have both working together.
What arduino board do you have?
gknight4
I'm using the LinkSprite Diamondback Arduino-Wifi board, and trying to add on the LSM303 Compass / Tiltmeter from Sparkfun. I had the problem with the Wifi + Compass combo sketches, and substituted the sketch from the examples for the SPI barometric pressure sensor. After it executes SPI.begin, the I2C gets stuck in an infinite loop.
I'm new at this, and just kinda combined the Compass and SPI sketches:
#include <SPI.h>
#include <Wire.h>
#include <LSM303DLH.h>
LSM303DLH compass;
  Serial.begin(57600);
  Wire.begin();
  compass.enable();
//  SPI.begin();
  DDRB=40 ;
Thumbs Up!
Gene Knight
nickgammon
There is no particular reason why it shouldn't work, and indeed I got SPI and I2C to work together between two Unos.
Master:
Code: [Select]
// Written by Nick Gammon
// July 2011
// SPI/I2C master
#include <SPI.h>
#include <Wire.h>
#include "pins_arduino.h"
#define SLAVE_ADDRESS 42
// command we might send
#define CMD_ID     1
void setup (void)
 Wire.begin();
 Serial.begin(115200);  // start serial for output
 // Put SCK, MOSI, SS pins into output mode
 // also put SCK, MOSI into LOW state, and SS into HIGH state.
 // Then put SPI hardware into Master mode and turn SPI on
 SPI.begin ();
 // Slow down the master a bit
 SPI.setClockDivider(SPI_CLOCK_DIV16);
}  // end of setup
void loop (void)
 char c;
 // enable Slave Select
 digitalWrite(SS, LOW);    // SS is pin 10
 // send test string
 for (const char * p = "Hello, world!\n" ; c = *p; p++)
   SPI.transfer (c);
 // disable Slave Select
 digitalWrite(SS, HIGH);
 delay (200);  // 200 mS delay
 Wire.beginTransmission (SLAVE_ADDRESS);
 Wire.send (CMD_ID);
 Wire.endTransmission ();
 Wire.requestFrom (SLAVE_ADDRESS, 1);
 if (Wire.available ())
   Serial.print ("Slave is ID: ");
   Serial.println (Wire.receive (), DEC);
 delay (1000);  // 1 second delay
}  // end of loop
Slave:
Code: [Select]
// July 2011
// SPI/I2C slave
#include <Wire.h>
char buf [100];
volatile byte pos;
volatile boolean process_it;
// command we might get
#define CMD_ID     1
#define MY_ADDRESS 42
char command;
void setup (void)
 Serial.begin (115200);   // debugging
 // have to send on master in, *slave out*
 pinMode(MISO, OUTPUT);
 // turn on SPI in slave mode
 SPCR |= _BV(SPE);
 // get ready for an interrupt
 pos = 0;   // buffer empty
 process_it = false;
 // now turn on interrupts
 SPCR |= _BV(SPIE);
 Wire.begin (MY_ADDRESS);
 Wire.onReceive (receiveEvent);  // interrupt handler for incoming messages
 Wire.onRequest (requestEvent);  // interrupt handler for when data is wanted
}  // end of setup
// SPI interrupt routine
ISR (SPI_STC_vect)
byte c = SPDR;  // grab byte from SPI Data Register
 if (!process_it)
   // add to buffer if room
   if (pos < sizeof buf)
     buf [pos++] = c;
     // example: newline means time to process buffer
     if (c == '\n')
       process_it = true;
     }  // end of room available
 } // if not waiting for previous one to be processed
}  // end of interrupt routine SPI_STC_vect
// main loop - wait for flag set in interrupt routine
void loop (void)
 if (process_it)
   buf [pos] = 0;
   Serial.println (buf);
   pos = 0;
   process_it = false;
   }  // end of flag set
}  // end of loop
void receiveEvent (int howMany)
  command = Wire.receive ();  // remember command for when we get request
} // end of receiveEvent
void requestEvent ()
switch (command)
  case CMD_ID:      Wire.send (0x55); break;   // send our ID
  }  // end of switch
}  // end of requestEvent
I connected together pins 10 .. 13 (for SPI) A4/A5 (for I2C) and +5V and Gnd.
Then uploaded both sketches and opened the serial monitor on each one.
One of them echoed back the "hello, world" that was being sent by SPI:
Code: [Select]
Hello, world!
Hello, world!
Hello, world!
Hello, world!
Hello, world!
Hello, world!
Hello, world!
Hello, world!
Hello, world!
The other one echoes back the slave ID that was requested by I2C:
Code: [Select]
Slave is ID: 85
Slave is ID: 85
The slave uses interrupts to process both SPI and I2C incoming.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
Personally I wouldn't be doing this:
Code: [Select]
DDRB=40 ;
For one thing it isn't clear which bits you are changing (as 40 is decimal). 0x28 would be slightly better. But why not do the pinMode function calls? That makes it much more self-documenting. Then you are not changing other pins which might have been initialized elsewhere (eg. in compass.enable(); ).
However you don't even need to change any pin modes. SPI.begin () does that. As explained in the Atmega328 manual on page 168:
Quote
When the SPI is enabled, the data direction of the MOSI, MISO, SCK, and SS pins is overridden according to Table 18-1 on page 168. For more details on automatic port overrides, refer to "Alternate Port Functions" on page 80.
terryking228
Nick, THANKS for explaining this; I didn't understand it...
One of the details that can Bite!
Regards, Terry King
...In The Woods In Vermont
terry@yourduino.com
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
gknight4
Oh, Arrgh. Sorry!
It was a, um,  intershield short between a header to attach a daughter board that was put in with the long pins *down*, and the ICSP pins sticking *up*. Hence the Digital Pin 11 (PB3) connection. (Darned reliable short! I've had connectors that didn't mate as reliably as these shorted pins did.)
OK, so far I've done this, I've attached Rx to Rx, I've bought shields with incompatible pin usage (The motor shield is a real pin hog! That's way too little utility for way too many pins!).
Is there a directory of classic beginners' stupidity out there, or do we all have to make it up for ourselves?
Thumbs Up!
Gene Knight
