Topic: Long Range Communications (Read 1 time) previous topic - next topic
aidan_aidan
I am looking for options on long range communications (around 10km - atmospheric), I don't need blazing crazy ass data rated either, even something modest like 9.6kbps would suffice. Any suggestions?
From what I saw about XBee, it doesn't have enough range for what I want.
Magician
zoomkat
You might do a Google search for "radio modems". Natures warning sign is that there are not a lot of examples of easy 10k communications floating about.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
peter224722
The problem is if you want to get 11km, no one can be on that frequency for around 30km2.
Because one point is north and the other point 11km south, they could be a stronger signal a little more to the north or one a little more to the south of you.
I was a radio ham and an 11km jump at 9k6 was not possible, to me the only way is by telephone ( Wifi ) or mobile phone.
I not sure about your country , but anything which would go that far would by licensed.
terryking228
Hi, Other key points:
- Are these two fixed locations?
- Is there unobstructed line-of-sight between locations??
- Can high-mounted directional antennas be used at both locations?
if so, you MAY be able to do this with one of the unlicensed bands....
MAYBE with 100mw from one of these??
http://arduino-direct.com/sunshop/index.php?l=product_detail&p=190
Regards, Terry King  ..In The Woods in Vermont
DISCLAIMER: Mentioned stuff from my own shop...
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
aidan_aidan
the ground station would be stationary, the other end would move every once in a while but very slowly, I live in Canada and I could use a directional antenna.
zoomkat
some wifi stuff.
http://pasadena.net/shootout05/
terryking228
You may be able to really push it with:
Like this Antenna: http://goo.gl/61daA   or this Amplifier:  http://goo.gl/Y8Tcu
Regards, Terry King
...In The Woods In Vermont
terry@yourduino.com
Simpson_Jr
You may also want to have a look at  http://en.wikipedia.org/wiki/WokFi, http://en.wikipedia.org/wiki/Cantenna and http://en.wikipedia.org/wiki/Wardriving.
The simplest wok- and so called cantennas systems probably won't give you much extra/reliable range.
If you would make 2 medium-sized dishes, build them good  and align the dishes well, 10 KM shouldn't be to difficult with a clear line of sight/enough height.
Besides transceivers it costs close to nothing.
mcb1
Guys
Here downunder my broadband is via a 2.4 GHz link.
It uses a low power unlicenced 'bullet' with a 24db Gridpack antenna over a 32Km link at 2MB (limited to this).
As far as I am aware the other end is reasonably omni directional, while my end is very narrow.
Antenna is :-
http://www.gowifi.co.nz/antennas/2.4-ghz/directional/2.4ghz-24dbi-parabolic-grid-directional-antenna.html
Bullet is :-
http://www.gowifi.co.nz/access-points-802.11/ubiquiti-bullet2-802.11b/g-100mw-outdoor-ap/bridge.html
Cheers
Mark
