Loading...
Pages: [1] 2   Go Down
Author Topic: Freeduino prototype pictures  (Read 1578 times)
Daniel
Guest
The ad-hoc international Freeduino team (with offices in Silicon Valley, Miami, Munich and Vancouver) is in the process of assembling four different Freeduino prototype boards. The good news is that they all worked the first time! It's kind of amazing that four people who have never met could design and proto the PCB for this in about three weeks. Plus, we had a lot of FUN doing it.
Pictures to follow, but here's a sneak peak of the first prototype of the 0805 version smiley
All the files are available at http://www.freeduino.org
« Last Edit: October 06, 2007, 05:32:15 am by Daniel » Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Hey,
I love how you guys are releasing all the design files.  I feel that is truly the way open source should be.  After all, the electronic files *are* the source for the real, physical objects.
Since you guys are using Eagle, you should really check out this script I wrote for the RepRap eagle files: https://reprap.svn.sourceforge.net/svnroot/reprap/trunk/reprap/electronics/eagle_package_release
Its really handy for creating .zip files for release.  Here's a short list of what it does:
* automatically creates GERBER and Excellon drill files
* automatically creates PDF files of board + schematics
* copies in eagle source files
* will create a 3D rendering (and soon flyover movie) of your board using Eagle3D: http://www.matwei.de/doku.php?id=en:eagle3d:eagle3d
* zips all those files into a nice, tidy .zip file you can post wherever.  see an example here: http://www.rrrf.org/dump/reprap-freeduino-dual-motor-driver-2007-10-03.zip
You have to run the eagle3D ulp before the script if you've made a change to the board, but its a 30 second process.  i'm working on automating it, but i dont know if its possible to run a .ulp from the command line.
Other than that, the release process is totally automated.  You run a command like this: ./eagle_package_release freeduino 1.16 and it would create a file like freeduino-v1.16.zip containing all the gerbers, pdfs, renders, and source files.  It reduces the chance of error in creating various file, as well as saving you tons of time to work on innovation rather than doing mundane stuff.
Yay!
« Last Edit: October 08, 2007, 12:11:33 pm by Hoeken » Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
I'll take a look.  Will it run on my Mac?
I'm not sure I believe in producing gerber and pdf files; that's akin to distributing binaries for open source software, and it multiplies the things that can go wrong (we've already run into inconsistencies in line width requirements for silkscreen layers; I went and used one of ULPs to increase the line widths, and the board producer wanted them back to the original values...)  (and you put tDocu in your silkscreen, but not tNames and tValues ! And the PDFs don't use drill-aid.  Oh, the horror!)
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Hmm.  You can take it or leave it, but it sure would seem weird if the Freeduino guys didn't want a simple solution for packaging up the files for release... isn't that the whole reason you forked?  I don't know about you, but working with open source projects that are source-only is a NIGHTMARE.
The script itself is very basic.  Its just a bash script that calls eagle, ps2pdf, and povray if you set it up to do 3D rendering (i highly recommend this... if you haven't looked at the rendering, its AMAZING!) If eagle runs from the command line on Macs, then yes.  I think you might need to make a symbolic link from ps2pdf to pstopdf (dunno why they renamed it on osx)  I've been running it from Linux and it works great.
As for generating the gerber files, its *very* simple to tweak what layers get printed.  I'm sort of a n00b when it comes to Eagle, so I don't fully understand which silkscreen layers are needed.  I think this is actually an argument *for* distributing a binary... ideally an expert will have configured the 'build' settings so you're getting a known good file.  Of course a disclaimer stating that you should double check with your manufacturer before ordering boards would be a fantastic, and common sense idea.
Personally, I don't think the gerbers are the main selling point of this script... rather the automatic generation of PDF files (including schematic), as well as a snazzy 3D rendering of the board make it a very nice way of generating files for a release.  You could also easily modify it to add in your README, documentation, license, etc. If you prefer to do all by hand, then be my guest.
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
Well. we "forked" cause the design files weren't available.  To me, that means .brd and .sch; I'm not sure there's any agreement among .. anyone... on the relative importance of the "production" files (or, *A* set of production files.  I suppose we'll have to decide just what we want in a "production distribution."    For instance, I'm not sure that PDFs are very useful once the board has design rules that rule out home fabrication (and the SSOP USB chip is pretty close.)  Once we decide, it certainly makes sense to have a script to produce them...
I had never realized that EAGLE3D was just ULPs+POVRay.  I thought there was a windows-only executable in there somewhere.  Thanks for pointing out that that's not the case!
You were also unable to get EAGLE to run a random ULP from the shell command line, eh?  Sigh.
You might want to import by modification for drill-aid (pilot hole) functions via the CAM PS output; see the eagle forums...
« Last Edit: October 08, 2007, 07:21:27 pm by westfw » Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Well, my gut feeling is that the production files, especially the exact GERBER files you used to get the boards manufactured should be released.  Having the source Eagle files is nice, but why not distribute the binaries as well?  In the time it takes you to reply to this, you could have this script up and running.  So there's one vote for distributing them.
Even if the boards are not easily made at home, it would still make sense to use the script to generate a PDF of the circuit schematic.  For someone who just wants to look at the circuit for whatever reasons, PDF is a much simpler option. Also, if there ever is a Freeduino that is designed for home etching, then generating these files automatically would be awesome.
As for running ULP's, there has to be a way.  I looked through the man page for Eagle, but I couldn't really find anything.  Adding that ability in would seriously up the potential for awesome on this build script.  Being able to run an arbitrary ULP would allow us to automate the Eagle3d stuff, drill aid, etc.  If anyone has experience and/or success with that... I'd love to hear from you.
I love what you're doing, and its nice to see the Arduino source files truly be opened up. Coming from a programming background, I know firsthand that there are real, useful reasons for a build system, and it definitely makes sense to apply them to electronic design tools if you can.  I seriously hope you consider using this script.  Having the GERBER scripts built automatically reduces the potential for human error.  Even if it is only you ordering boards from those files, if it prevents you from accidentally wasting $100+ because you forgot one little step, then it would be worth it.
Logged
USA
Offline Offline
Sr. Member
Freeduino rocks
View Profile
WWW
Hoeken, having software background you will understand the analogy I will use:
Your request is like asking Linus Torvald why he does not create a Linus Distro.  He doesn't have the time nor the monetary interest to do it.  I am sure he is pretty busy keeping an eye on the Kernel and its evolution.
Know you can enjoy free binary distribution of open software, because the platform is more uniform and there are a lot of people contributing to the open source projects.  In the beginning times of open source, you only had source distribution, and you put your effort to make it work, port it to different platforms, etc.  This is community work.
The Freeduino Team is working on designing an open Arduino compatible board, so anyone can enjoy it, as you probably enjoy Linux.  Their mission is not to make everybody's life easier, creating the Gerber files, like Linus does not work for the community creating the Linus Distro.  There are companies like RedHat, Suse and many others adding to the engineering and commercial side of the equation, as you should be contributing with new boards, generating and publishing the Gerber files, etc, if you really like Freeduino.  The team created gerber files so they can prototype the original Freeduino schematics, but the Team does not want to impose any particular board design.  With the contributions of many, we will get sooner to SuperFreeduino, don't you think?
The Freeduino team really enjoys CONTRIBUTIONS, like your comment about PDFs, as not everybody has access (and knowledge) to use Eagle.  But Gerber files?  How many Arduino users know what Gerber is?  Do they care?
Logged
USA
Offline Offline
Sr. Member
Freeduino rocks
View Profile
WWW
Quote
Using a beta (or alpha) software to generate production Gerber files?  Hmmm, you must be an excellent programmer  smiley-wink
Logged
USA
Offline Offline
Sr. Member
Freeduino rocks
View Profile
WWW
Quote
I am n00b to 3D rendering with Eagle.  Does it render povray for any component that you put in your board or you need some sort of 3D library?  I tried 3D rendering in KiCad, but the lack of 3D libraries is a limitation... it looks pretty amazing, though.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Quote
Well, the Linux example is a bit of a stretch, but still fairly accurate.  However, note that the kernel source is also distributed with a makefile for building it. smiley-razz
Quote
Well, that is what i was trying to do here... contribute.  I wrote a script, and it works.  I use it as part of another open source project, and it has made my life easier.  I thought you guys might be interested in that as well.  I'd say I'm a part of the community here and I want to help!
Why isnt the mission to make peoples lives easier?  I mean if you really want to make this more confusing by having one place where you get the source and then another place to get the gerbers.  This is where the linux analogy breaks down.  While there are variants, the variants are really all about board layout.  Since you're distributing the board layout source, you might as well distribute the generated files from it.  Would you distribute the schematic but not the layout?  Since you guys aren't just doing the raw source (schematic) but the compiled object (real boards) then you are creating both source *and* variant.
Quote
Well, the type of people that are interested in the Eagle files for the Freeduino board, definitely!  Even if you do know how to make the Gerber files manually, why would you want to?  If there is a way to automate it, and get extra bonus features as well, why not do it?  You know you can manually type gcc in the command line, but why would you want to when there is make?  At the very least it would be nice to include the script in the distribution to automate creation of gerber files as a convenience.  Also, what if there is someone who doesn't know a whole lot about the eagle files, but would like to order 200 boards for his school.  Being able to take a zip file, email it to a manufacturer and have them make it would help that person tremendously.
I'm sorry if this is rubbing you guys the wrong way, but I seriously just want to help.  Please give the idea a couple days to sink in and maybe you'll come around to it.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Quote
Quote
look at it this way: how do you want your production files generated?
* by hand, where every time you generate them there is the potential for making a mistake?
or
* from a script, that has a set process, is repeatable, can be looked at and verified by others?
sure, the script might have a bug or two in it, but its easy to look at the gerber files and verify that they are correct.  also, the script is dead simple.  here is the part that generates gerbers and the drill file:  if you spot any errors, please let me know!
#create our gerber files!
echo "Creating Gerber Files..."
eagle -X -N -d GERBER_RS274X -o "$TO_DIR/gerber/ComponentTraces.pho" $BOARD/*.brd Top Pads Vias
eagle -X -N -d GERBER_RS274X -o "$TO_DIR/gerber/CopperTraces.pho" $BOARD/*.brd Bottom Pads Vias
eagle -X -N -d GERBER_RS274X -o "$TO_DIR/gerber/SolderMaskComponent.pho" $BOARD/*.brd tStop
eagle -X -N -d GERBER_RS274X -o "$TO_DIR/gerber/SolderMaskCopper.pho" $BOARD/*.brd bStop
eagle -X -N -d GERBER_RS274X -o "$TO_DIR/gerber/SilkScreen.pho" $BOARD/*.brd Dimension tPlace tDocu
# Drill data for NC drill st.
# warning : eagle takes path of -R option from input file directory.
eagle -X -N -d EXCELLON -E -0.02 -E 0.1 -R ${BOARD}.drl -o $TO_DIR/gerber/${BOARD}.drd ${BOARD}/*.brd Drills Holes
cp $BOARD/*.drl $TO_DIR/gerber
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Quote
Quote
eagle3d comes with a large library of parts, and can substitute generic parts for chips with a standard housing.  it will even put your chip name on the generic housing.  its pretty neat actually.  it also allows you to add description data in the schematic that automates the process a little bit more.  eagle3d is actually really well developed and is very powerful.
it might require a little bit more work, but the image generated is pretty awesome looking.  the pictures in the zip files above are just the first run.  i opened my schematic, ran the ulp with default settings, then ran povray.  it missed a couple parts, but overall it did a great job.
Logged
Daniel
Guest
@hoeken:
I don't think we're against any particular release method.. we haven't got that far yet. We're moving very happily through the mechanics of the process, having fun, and amazed by the very cool results!
I have a package with the Gerbers used for the last proto somewhere... and will post it when I get the chance. Whenever we have the final Gerbers for a version, they will of course be available! There'll be no holding back, it's just a matter of getting the time to get the details.
Also, if there is some version, like a custom package you would like people to have access to through the Freeduino site, just PM me and we'll set it up. Similarly, nothing prevents you from making your own release or versioning... Eventually I guess we should set up a wiki for people to add their packages, so that the different variations can detemrine the direction of what ever this "freeduino" thing is... but like I said, we are just at the stage of building the prototype boards we've received, and I think it is safe to say we are all a little stunned by how quickly  open-source collaboration can produce the physical objects we're currently staring at!
D
Logged
Daniel
Guest
OK Gerbers for the first prototype run are posted at Freeduino.org. Initial assembly of each of these designs ( 0603, 0805,1206, TH) worked! We're trying to find the Eagle files for that version. it was a mad rush to make the deadline for the PCB house.
D
edit: a complete package that includes Gerbers, drill files and all four Eagle layouts is now posted. this is the same info that was sent to the board house to produce the prototypes.
« Last Edit: October 10, 2007, 03:13:38 am by Daniel » Logged
Augsburg/Munich, Germany
Offline Offline
Jr. Member
"Stay hungry. Stay foolish."
View Profile
Hey, Hoeken, I think it's great to use such a script in the end!
For now things like collaborative work on (shared) eagle files are a bit more interesting :-)
Do you know anything about this as you have ULP experience?
I tried to work from eagle scripts (.scr) beeing generated by modified export-board.ulp and export-schematic.ulp.
A .scr file is at least ASCII text (i.e. eagle comands) wich could be much better handled by SVN or similar versioning systems than .brd or .sch, beeing binary... any sugeggestions? anyone else?
Logged
Pages: [1] 2   Go Up
Print
Jump to:
