Loading...
Poll
Question: what are transitors
Lumps of silicon - 2 (25%)
Lumps of germanium - 2 (25%)
Doped - 4 (50%)
Total Voters: 8
Pages: 1 2 [3] 4   Go Down
Author Topic: What are transistors.  (Read 1631 times)
Chateauguay
Offline Offline
Full Member
-8 years old: LEGO BLOKS 8 to 9 years old: little cards magician 9 to 12 years old : meccano 13 years old: Arduino Uno!!!! Usually my real dream was to make little gadjets and that sort of stuff =)
View Profile
WWW
IRF520 Mosfet Transistor
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Now you tell me!!!!!
That is a FET it is not a transistor. All that stuff about how a transistor works is not relevant to your device. What is more your device requires 10V to turn it on. This is more than the arduino can supply so in general  you can't use this device with the arrangement you have been looking for.
So how did you identify the emitter base and collector on you device because it doesn't have them. It has a gate drain and source. So basically you have been lying when you say you have.
Logged
Toronto, Canada
Offline Offline
Edison Member
"Keep it R.E.I.L. - "Research, Experiment, Investigate and Learn"
View Profile
I was having a feeling that was a MOSFET. That will explain the transistor got hot.  Kiss goodbye the LED. I hope the Arduino is still working. Why you simply use a 2N3904 or something like that ?  No parts, right ?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
So what does the T in FET stand for?  smiley-grin
Logged
Toronto, Canada
Offline Offline
Edison Member
View Profile
About the poll. The answer is None of the above. They are silicon type - 2N3904  and also germanium type - 2SB56. <-- That one is a oldie
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
About the poll....I made it up   smiley-twist  (because I couldn't remove it)
(I have an OC71 in my spares drawer, and an OCP71 I made by scraping the paint off an OC71)
« Last Edit: August 02, 2011, 11:17:56 am by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Online Online
Brattain Member
View Profile
WWW
Quote
Don't know?
However he did talk about E B and C so it was a fair guess it was a bipolar.
How can you hope to identify the leads as EBC when you have a FET?
Quote
I have quite a few OC28 these are power transistors.
Logged
Chateauguay
Offline Offline
Full Member
View Profile
WWW
what does MOSFET Transistors do?
connect the ground to the left pin
connect the 5 v to the center pin
connect the right pin to a motor
and connect the motor pin 13
it still does nothing
and this thransistor was in arduino uno kit
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
Well, there's always Google.
Logged
Chateauguay
Offline Offline
Full Member
View Profile
WWW
i cant find any useful information
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
Take a look at this Tutorial about FET , pictures and circuit
http://brunningsoftware.co.uk/FET.htm
And this :
http://brunningsoftware.co.uk/Transisor.htm
« Last Edit: August 02, 2011, 01:44:56 pm by Erni » Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
I'm astonished.
Logged
Online Online
Brattain Member
View Profile
WWW
Quote
Well complain because it can't be used directly without another NPN transistor, it is not a logic level device it requires 10V to operate it correctly.
Note that this tutorial:-
Will not work with the FET you have.
Logged
Chateauguay
Offline Offline
Full Member
View Profile
WWW
so this mean an NPN transistor is way more better then a MOSPHET transistor?  smiley-confuse
and does it also mean that MOSPHET transistors won't be useful in any of my futur projects  smiley-confuse
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
Woah!
Slow down.
What does any online search facility say about "MOSPHET"s ?
What, in fact, is a "MOSPHET" ?
Start doing some of your own research, before falling back on this forum.
Logged
Pages: 1 2 [3] 4   Go Up
Print
Jump to:
