Topic: Programming tomb!!! (Read 2026 times) previous topic - next topic
ejahable
Aug 01, 2011, 01:58 am Last Edit: Aug 01, 2011, 02:01 am by ejahable Reason: 1
I will be 4ft underground if I don't get this to work. I spent 5 days already trying to figure out solutions but is just not working.  :(
I need an object that receives two parameters:
  1) a number (0 to 99999 "long type")
  2) a place number (0 to 5 "int type")
with these parameters it returns the digit of the number determine by the place number.
example 1:
1)  number:           56789
2)  place number:  1
 it returns 9
example 2:
1)  number:           56789
2)  place number:  2
 it returns 8
I believe that I made my point, I added my code below. Nevertheless I can't get it to work without overflowing. Any suggestions will be appreciated.
Thanks in advance.
Code: [Select]
int getDigit(long number,int place){
 if(place == 1){return (number-((int(number*0.1))*10));}
 else if(place == 2){return (int((number-((int(number*0.01))*100))*0.1));}
 else if(place == 3){return (int((number-((int(number*0.001))*1000))*0.01));}
 else if(place == 4){return (int((number-(long(int(number*0.0001)))*10000)*0.001));}
 else{return (int(number*0.0001));}
crimony
How about:
Code: [Select]
#include <math.h>
int getDigit(long number, int place)
    return ((number / long(pow(10, place - 1))) % 10);
ejahable
So I used your code like such:
Code: [Select]
#include <math.h>
boolean boo = true;
void setup(){
void loop(){
  while(boo){
    delay(4000);
    Serial.println(getDigit(56789L,1));
    Serial.println(getDigit(56789L,2));
    Serial.println(getDigit(56789L,3));
    Serial.println(getDigit(56789L,4));
    Serial.println(getDigit(56789L,5));
    boo = false;
and got as result:
9
8
3
6
5
Your code is ingenious but it stills has problems. Thanks
crimony
I don't have my Arduino here so I can't test, but it works fine on Linux using int as long and short as int. Must be an Arduino integer or math library issue.
You will need to split the functionality up and see at what point it is failing:
Code: [Select]
    double p = pow(10, place - 1);
    long l = long(p);
    long n = number / l;
    long m = n % 10;
    // Debug output
    Serial.print("getDigit() called, number = ");
    Serial.print(number);
    Serial.print(", place = ");
    Serial.print(place);
    Serial.print(", l = ");
    Serial.print(l);
    Serial.print(", n = ");
    Serial.print(n);
    Serial.print(", m = ");
    Serial.println(m);
    return int(m);
johnwasser
pow() returns a float.  Arduino is MUCH happier with integers:
Code: [Select]
   for (; place>1; place--)
      number /= 10;   // Shift right one decimal digit
   return number % 10;  // Return rightmost decimal digit
[/quote]
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
nickgammon
6 ft surely?
Try converting to a string:
Code: [Select]
int getDigit (long number, int place)
char buf [12];
ltoa (number, buf, 10);
// sanity clause
if (place <= 0 || place > strlen (buf))
   return 0;
// extract digit
return (buf [strlen (buf) - place] - '0');
}  // end of getDigit
void setup ()
  Serial.begin (115200);
  for (int i = 1; i <= 10; i++)
    Serial.println (getDigit (56789L, i));
  Serial.println ();
    Serial.println (getDigit (2147483648L, i));
}  // end of setup
void loop ()
Example output:
Code: [Select]
9
8
7
6
5
0
0
0
0
0
8
4
6
3
8
4
7
4
1
2
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
crimony
Quote
Agreed, but I set myself the goal of trying to do it in one line (not counting the #include).
Utopia
This feels suspiciously like a homework assignment, but I'll bite:
Code: [Select]
unsigned int homework(unsigned long x,unsigned int m)
  while (--m)
    x/=10;
  return x%10;
Will work for 1-max digits in number, unsigned only; no guarantees outside of that...
Utopia
... just noticed johnwasser already wrote code that works, so didn't need to include mine - however, it's already done, it's another variation, so I'll leave it be (sorry john - should have checked more carefully).
nickgammon
Code: [Select]
// sanity clause
http://www.marx-brothers.org/info/quotes.htm
http://en.wikipedia.org/wiki/There_Ain't_No_Sanity_Clause
ejahable
Thanks all of you, I really appreciated!! and no its not for school.  :smiley-yell:
lol, you all guys really know this stuff. Kudos!!  8)
