Author Topic: Programming tomb!!!  (Read 880 times)
I will be 4ft underground if I don't get this to work. I spent 5 days already trying to figure out solutions but is just not working.  smiley-sad
I need an object that receives two parameters:
   1) a number (0 to 99999 "long type")
   2) a place number (0 to 5 "int type")
with these parameters it returns the digit of the number determine by the place number.
example 1:
 1)  number:           56789
 2)  place number:  1
  it returns 9
example 2:
 1)  number:           56789
 2)  place number:  2
  it returns 8
I believe that I made my point, I added my code below. Nevertheless I can't get it to work without overflowing. Any suggestions will be appreciated.
Thanks in advance.
int getDigit(long number,int place){
  if(place == 1){return (number-((int(number*0.1))*10));}
  else if(place == 2){return (int((number-((int(number*0.01))*100))*0.1));}
  else if(place == 3){return (int((number-((int(number*0.001))*1000))*0.01));}
  else if(place == 4){return (int((number-(long(int(number*0.0001)))*10000)*0.001));}
  else{return (int(number*0.0001));}
« Last Edit: July 31, 2011, 07:01:59 pm by ejahable » Logged
Australia
How about:
#include <math.h>
int getDigit(long number, int place)
    return ((number / long(pow(10, place - 1))) % 10);
So I used your code like such:
#include <math.h>
boolean boo = true;
void setup(){
void loop(){
  while(boo){
    delay(4000);
    Serial.println(getDigit(56789L,1));
    Serial.println(getDigit(56789L,2));
    Serial.println(getDigit(56789L,3));
    Serial.println(getDigit(56789L,4));
    Serial.println(getDigit(56789L,5));
    boo = false;
and got as result:
9
8
3
6
5
Your code is ingenious but it stills has problems. Thanks
Australia
I don't have my Arduino here so I can't test, but it works fine on Linux using int as long and short as int. Must be an Arduino integer or math library issue.
You will need to split the functionality up and see at what point it is failing:
    double p = pow(10, place - 1);
    long l = long(p);
    long n = number / l;
    long m = n % 10;
    // Debug output
    Serial.print("getDigit() called, number = ");
    Serial.print(number);
    Serial.print(", place = ");
    Serial.print(place);
    Serial.print(", l = ");
    Serial.print(l);
    Serial.print(", n = ");
    Serial.print(n);
    Serial.print(", m = ");
    Serial.println(m);
    return int(m);
Massachusetts, USA
pow() returns a float.  Arduino is MUCH happier with integers:
   for (; place>1; place--)
      number /= 10;   // Shift right one decimal digit
   return number % 10;  // Return rightmost decimal digit
[/quote]
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
Lua rocks!
6 ft surely?
Try converting to a string:
int getDigit (long number, int place)
 char buf [12];
 ltoa (number, buf, 10);
 // sanity clause
 if (place <= 0 || place > strlen (buf))
   return 0;
 // extract digit
 return (buf [strlen (buf) - place] - '0');
 }  // end of getDigit
void setup ()
  Serial.begin (115200);
  for (int i = 1; i <= 10; i++)
    Serial.println (getDigit (56789L, i));
  Serial.println ();
    Serial.println (getDigit (2147483648L, i));
}  // end of setup
void loop ()
Example output:
9
8
7
6
5
8
4
6
3
8
4
7
4
1
2
Australia
Agreed, but I set myself the goal of trying to do it in one line (not counting the #include).
Victoria, BC, Canada
This feels suspiciously like a homework assignment, but I'll bite:
unsigned int homework(unsigned long x,unsigned int m)
  while (--m)
    x/=10;
  return x%10;
Will work for 1-max digits in number, unsigned only; no guarantees outside of that...
... just noticed johnwasser already wrote code that works, so didn't need to include mine - however, it's already done, it's another variation, so I'll leave it be (sorry john - should have checked more carefully).
Lua rocks!
 // sanity clause
http://www.marx-brothers.org/info/quotes.htm
http://en.wikipedia.org/wiki/There_Ain't_No_Sanity_Clause
Thanks all of you, I really appreciated!! and no its not for school.  smiley-yell
lol, you all guys really know this stuff. Kudos!!  smiley-cool
