Topic: Interfacing Atomic IMU 6DOF (Read 2424 times) previous topic - next topic
rahlk
I made all the necessary connections between IMU and the arduino mega
I managed to connect the atomic IMU 6DOF to the mega and used the code(given below) to read the data. I am getting a set of distinct numbers that actually make no sense at all..
Code: [Select]
int imuData[9];
  Serial.println("#");
  Serial.println("-");
  for(int i=0; i<9; i++) {
    imuData[i]=Serial.read();
    Serial.print(imuData[i]);
    Serial.print("__");
Serial.println("");
delay(900);
Please help me with this.
-RaHL
PaulS
Quote
You want to share that output, and explain your expectations?
rahlk
this is what i am getting. Well, as far as i know these numbers dont make any sense. i am hoping to get some numbers pertaining to angles or speed of something, know what i am talking about?
PaulS
Quote
The problem is that your expectations are unrealistic. What you are getting is the instantaneous acceleration data and orientation data. Since acceleration is the rate of change of velocity, you need to integrate that data to get speed. There are plenty of examples around for how to do this. Some even work.
rahlk
Okay, after quite some research i found that the data from the IMU arrives in a bit mode distributed like this:-
8 bits      16bits      16bits      16bits      16bits      16bits      16bits      16bits      8bits
  'A'         Count       X accl      Y accl      Z accl      Roll          Pitch        Yaw         'Z'
So i use this code snippet
Code: [Select]
int imuVal[16];
for(int i=0; i<16; i++) {
     imuVal[i]= Serial.read();
This imuVal array will now contain the raw data, how do I convert it to something meaningful?
