Loading...
Pages: [1]   Go Down
Author Topic: Looking for options: Small, bare AC/DV 12V 1.5A PSU  (Read 611 times)
Offline Offline
Full Member
View Profile
I need to throw a 12V 1.5A power supply into a box that's roughly 5"x5"x3" and still have room for a board I've been asked to make.   The board can be as small as .5"x3" depending on how tight I've got to make those components. Luckily, I've got very small chip options.
I've looked for transformers that will fit in a case that size, and while I've seen dozens of switching power supplies that are that small, I've not been able to find a transformer rated at my needed current levels that's small enough (and preferably pcb mounted) to handle the job.  I've used EI-30 form factor transformers for lower power jobs and have been happy, but at 2VA, they're obviously unsuitable.
Anyone have any favorite options?
thanks!
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Must the supply be mounted inside the box? If this box is going to be AC wall outlet powered anyway not something like this:
http://www.allelectronics.com/make-a-store/item/PS-1228/12-VDC-1.5A-SWITCHING-POWER-SUPPLY/1.html
Lefty
Logged
Offline Offline
Full Member
View Profile
Unfortunately, the transformer etc must all be inside the same (small) box as the MCU itself.   Shielding and other concerns are going to have to be dealt with.
Logged
Offline Offline
Jr. Member
View Profile
 see here      www.jameco.com/ mybe one fit for you
Logged
Offline Offline
Full Member
View Profile
Thanks - I had looked at those earlier.   I'm looking for (essentially) as small a version of THIS as possible:
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_1919051_-1
It just strikes me that with the rather large number of (smaller than this) wall warts that are in the 12v/1.5A range, that there might be smaller (than this) units out there bare like this.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
How about this one?
http://www.mpja.com/prodinfo.asp?number=18668+PS
Could you also accept 2 smaller units?
http://www.dipmicro.com/store/DCA-1210
Make sure to get all your grounds connected so every one is at the same ground reference level.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Full Member
View Profile
Crossroads, are you suggesting that i buy these and take them apart?  I've considered doing just that, but it's not a good long-term solution for me.
Logged
Offline Offline
Full Member
View Profile
This is closest yet:
http://www.mpja.com/prodinfo.asp?number=18439+PS
It's still larger than what would be found in the smallest DC wall warts.   My issue if getting this wouldn't be having space for my board, but would be having space for my board + one accessory connector + (the big one) shielding between the psu and mcu.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
The 1st one I suggested just use as is, connect the 2 pins to whatever AC receptacle you are using.
If you have a 5"x5" box, that raises up 3" this can lay in the bottom and still give tons of room in  your box - 3"x3"x5".
Or cut an opening, let the square part and the power prongs stick out, plug an extension cord on the end of it. Couple of small holes and secure it to the face with cable ties.
Wish I had a way to post a quick drawing.
Logged
Offline Offline
Full Member
View Profile
No, I see where you're going.   The issue is that this is a commercial product, not one of my arduino projects.   Gotta look classy smiley
I'm using an IEC C8 for the power cord, so there is a bit of space taken up there (I've accounted for this space before giving dimensions above)
Logged
Offline Offline
Full Member
View Profile
In case anyone isn't aware of the type of jack I'm talking about:
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Well, if you can't find a little bare board to put in, then trim the AC plugs and solder wires from the plug to the trimmed legs.
Logged
Minnesota, USA
Offline Offline
Jr. Member
Arduino rocks
View Profile
Have you considered what effect 15 Watts is going to have in an enclosure that small?
This one might meet your requirements, though it'll take a little finagle'in with PC Pins.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=945-1090-ND
CONV AC/DC 20W 12V OUT 1.65A
2.06" L x 1.07" W x 0.93" H (52.4mm x 27.2mm x 23.5mm)
Logged
Pages: [1]   Go Up
Print
Jump to:
