Loading...
Pages: 1 [2]   Go Down
Author Topic: A new arduino board?  (Read 903 times)
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Hey.  Am I seeing right?   The Duemilanove is slightly cheaper than the Diecimila?   That's a rather pleasant surprise!  Extra functionality at less cost - yeah!
Logged
0
Offline Offline
God Member
Arduino rocks!
View Profile
Where are you seeing a price for the '09?  I see Ladyada's lowered the price on the Dieci to clear it out in anticipation of the new model but none of the usual suspects seem to list it yet.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
This is the only online place I've seen it and it is under $30 USD.
http://www.nkcelectronics.com/arduino-diecimila.html
Logged
USA
Offline Offline
Sr. Member
Freeduino rocks
View Profile
WWW
One clarification... the link says arduino-diecimila.html, but it points to the new arduino duemilanove product.
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
Also seen at fungizmos and liquidware.  In general, it looks like duemilanove has a price around $33, while Diecimila is around $35.
It's not  BIG change in price, but it's sorta nice to see.
NKC's $29.95 appears anomalous - get them while you can!
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
That's pretty cheap smiley
Time to stock up smiley
Logged
Los Angeles CA
Offline Offline
Newbie
View Profile
WWW
There are some other options. I'm sure this doesn't cover them all, but cheaper boards I'm aware of:
ModernDevices makes the RBBB ($12 kit, $21 assembled) and BBB ($15 kit, $25 assembled), which are no-USB boards perfect for "production" or breadboarding. A generic USB->serial cable is available for $20.
NKC Electronics has the iDuino, a USB 'duino ($18 kit, $23 assembled), as well as the Freeduino- a shield-compatible 'duino ($24 kit).
HVWTech (a SolarBotics company) sells the Freeduino SB (shield-compatible 'duino), ($26 kit), as well as the Boarduino, a breadboard-style that needs a USB-serial cable ($20 kit).
Phew!
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
The official arduinos are very nice smiley
In some cases though you may need something smaller or different like the boards mentioned by tedder
There is also the dorkboard http://www.dorkbotpdx.org/ which sells for about $10
It is incredibly small, it is half the size of a RBBB from modern device, 1/4 the size of a BBB from modern device, about 1/4 the size of an iDuino from Fundamental logic and about 1/6 to 1/8 the size of the official Arduino
Unfortunately the Dorkboard uses 2 SMT resistors which can be very difficult to solder, has a 5pin programming header which does not work with the 6pin FTDI cable, as far as I know, and does not have a voltage regulator onboard, which is a good thing and a bad thing
You either have to power it with a battery or an external regulated power supply
I have several of most of the boards tedder mentioned and a dorkboard and a few other boards
smiley
« Last Edit: October 26, 2008, 08:35:29 pm by gnu_linux » Logged
Pages: 1 [2]   Go Up
Print
Jump to:
