Topic: problem with scketch upload (Read 662 times) previous topic - next topic
insippo
core.a(main_orig.cpp.o): In function `main':
/home/insippo/arduino-0022/hardware/arduino/cores/arduino/main_orig.cpp:7: undefined reference to `setup'
/home/insippo/arduino-0022/hardware/arduino/cores/arduino/main_orig.cpp:10: undefined reference to `loop'
ubuntu 10.04, arduino duemilanove and eth shield w5100 with sd card. If i connect eth shield to arduino usb connection filed.
if i upload without eth shield : core.a(main_orig.cpp.o): In function `main':
/home/insippo/arduino-0022/hardware/arduino/cores/arduino/main_orig.cpp:10: undefined reference to `loop'  again this error
what the problem ?
thanks
MarkT
Does the sketch contain  setup() and loop() function definitions?  This error suggests the compiler can't find them.
insippo
#2
Aug 03, 2011, 06:46 pm Last Edit: Aug 03, 2011, 06:49 pm by insippo Reason: 1
if i connect w5100 shield to arduino, arduino disconnect from usb port and arduino ide says:
Error inside Serial.serialEvent()
java.io.IOException: Input/output error in nativeavailable
   at gnu.io.RXTXPort.nativeavailable(Native Method)
   at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)
   at processing.app.Serial.serialEvent(Serial.java:215)
   at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
   at gnu.io.RXTXPort.eventLoop(Native Method)
   at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
ubuntu 10.04 and ubuntu 10.10 arduino duemilanove+w5100 with sd card reader
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
