Loading...
Pages: [1]   Go Down
Author Topic: BUG: delayMicroseconds(0) leads to a huge delay  (Read 1265 times)
Canada
Offline Offline
Newbie
View Profile
Passing zero to the delayMicroseconds function leads to a huge delay.  If the parameter is calculated inside of a user code, this zero can be unexpected outcome leading to the confusing huge delay.
In the implementation of the function, in the "wiring.c" file, the function parameter is pre-decremented, effectively switching this zero to a large value.
/* Delay for the given number of microseconds.  Assumes a 8 or 16 MHz clock. */
void delayMicroseconds(unsigned int us)
   // calling avrlib's delay_us() function with low values (e.g. 1 or
   // 2 microseconds) gives delays longer than desired.
   //delay_us(us);
#if F_CPU >= 16000000L
   // for the 16 MHz clock on most Arduino boards
   // for a one-microsecond delay, simply return.  the overhead
   // of the function call yields a delay of approximately 1 1/8 us.
   if (--us == 0)
      return;
   // the following loop takes a quarter of a microsecond (4 cycles)
   // per iteration, so execute it four times for each microsecond of
   // delay requested.
   us <<= 2;
   // account for the time taken in the preceeding commands.
   us -= 2;
#else
   // for the 8 MHz internal clock on the ATmega168
   // for a one- or two-microsecond delay, simply return.  the overhead of
   // the function calls takes more than two microseconds.  can't just
   // subtract two, since us is unsigned; we'd overflow.
   if (--us == 0)
      return;
   if (--us == 0)
      return;
   // the following loop takes half of a microsecond (4 cycles)
   // per iteration, so execute it twice for each microsecond of
   // delay requested.
   us <<= 1;
   // partially compensate for the time taken by the preceeding commands.
   // we can't subtract any more than this or we'd overflow w/ small delays.
   us--;
#endif
   // busy wait
   __asm__ __volatile__ (
      "1: sbiw %0,1" "\n\t" // 2 cycles
      "brne 1b" : "=w" (us) : "0" (us) // 2 cycles
« Last Edit: August 03, 2011, 04:27:20 pm by atetervak » Logged
Centurion RSA
Offline Offline
Full Member
Arduino rocks
View Profile
Why would one pass a zero to a delay function? Dangerous I would say.
Logged
Rather people think you to be a fool than you open your mouth and confirm it.
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
If the function parameter is being calculated as the output of integer division:
delayMicroseconds(1000/1500); would give a 0 value to the parameter unexpectedly.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
So do the calculation first & test it - if the result is less than 3 don't call the delay:
"Caveats and Known Issues
This function works very accurately in the range 3 microseconds and up. We cannot assure that delayMicroseconds will perform precisely for smaller delay-times. "
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Canada
Offline Offline
Newbie
View Profile
Code:
float my_rate(float x){
    // something here
float my_scale = 1.5;
// something here
delayMicroseconds(int(my_scale*my_rate(something_calculated)));
Logged
Canada
Offline Offline
Newbie
View Profile
This function works very accurately in the range 3 microseconds and up. We cannot assure that  will perform precisely for smaller delay-times. "
I do not accept your argument. It is well expected and understood that delayMicroseconds(0) won't give literally zero delay  smiley-lol. Nevertheless, it is natural to expect (from the website statement) that the actual delay would be below or somewhat close to delayMicroseconds(3), this would be fine. It is totally unexpected that delayMicroseconds(0) function call produces delayMicroseconds(UINT_MAX) delay.  I insist that it is a BUG.
« Last Edit: August 04, 2011, 09:50:20 am by atetervak » Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
I'd INSIST that that code doesn't compensate correctly for the amount of processing necessary to perform those float-point operations.     smiley-grin
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
A great deal of the arduino interface is to make it easy to write code: x = digitalRead(pin);     instead of low(er) level code.
People expect a certain behavior of these functions, and  atetervak  is expecting behavior of delayMicroseconds() which is in my opinion 100% reasonable. I also agree with his statement:
Quote
On the other hand his example of the "calculated delay" is not strong, partly because it uses float math that is "slow" compared to micros (as AWOL states). But one could have a similar problem when using integer math, which is in the same order of speed.
But whether you call it a bug or not, it is unexpected behavior, that can easily be fixed by changing a few lines in the code of delayMicroseconds():
(original code)
Code:
if (--us == 0)
  return;
(proposed code)
Code:
if (us < 2)
  return;
us--;
where the first would only capture us =  { 1 } the second captures both us = { 0,1 }
Not measured as I don't have an arduino at hand, but I expect the accuracy and speed will be similar.
Footprint is increased with 2 bytes (for 328, I do have a compiler smiley .
Can't report it as a bug/fix at the moment as the site - http://code.google.com/p/arduino/issues/list - is not available ...
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Netherlands
Offline Offline
Tesla Member
View Profile
addition
for the 8 Mhz version of delayMicrosecond()
Code:
if (us < 3)
  return;
us -=2;
Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
Problem reported as an issue  - http://code.google.com/p/arduino/issues/detail?id=576
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
