Pages: 1 [2] 3 4   Go Down
Author Topic: LCD does not work unless Arduino is reset.  (Read 2804 times)
Central MN, USA
strange. I start to suspect your code or other hardware but I know you checked thoroughly. I buy from chinaecomponents on ebay. Never a problem.
United Kingdom
I still thihk the problem is that the device is not ready when the begin() command send commands to the device. I suggest trying the following, one at a time:
1. Make sure you have a call to lcd.begin(...) in setup - assuming your LiquidCrystal variable is called "lcd".
2. Add a delay in setup() before the begin(...) call as per retrolefty's suggestion.
3. If that doesn't fix it, the problem may be that the lcd.begin() call in the LiquidCrystal constructor is happening too soon. Preferably, recompile the LiquidCrystal library with the begin() call at LiquidCrystal.cpp line 82 commented out. Alternatively, the following may work (it compiles but is otherwise untested):
  • Replace the declaration "LiquidCrystal lcd(...);" by the following:
void* operator new(unsigned int sz)
  return malloc(sz);
LiquidCrystal *pLcd;
  • Put the following in setup, before the lcd.begin(...) call:
  delay(1000);    // delay as per retrolefty's suggestion
  pLcd = new LiquidCrystal(...);   // insert correct pin numbers here
  • Replace every instance of "lcd." by "pLcd->"
South UK
hey there. I do have a call to begin in the set-up.
I have tried al sorts of delay times before the begin but does not seem to help
I not sure how I recompile the library?
I just tried the last suggestion, replacing some of the bits but could not get that too complie smiley-sad
United Kingdom
What compile errors are you getting, and on what lines? If you post your sketch, I can try making the changes and see what problems there are compiling it.
« Last Edit: September 05, 2011, 06:41:41 am by dc42 » Logged
South UK
Hi there, here is what I have currently
#include <LiquidCrystal.h>
  return malloc(sz);
//LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int analoginput = 0;
int analoginput1 = 1;
int analoginput2 = 2;
float vin = 0.0;
float vin1 = 0.0;
float vin2 = 0.0;
void setup(){
  pLcd = new LiquidCrystal(7, 8, 9, 10, 11, 12);   // insert correct pin numbers here
delay(100);
 pLcd.begin(16, 2);
delay(100);
    pLcd.setCursor(0, 0);
   pLcd.print("REAPsystems V1.1");
       lcd.setCursor(0, 1);
   pLcd.print("iSensor tester");
delay(4000);
  pLcd.clear();
void loop(){
     delay(1400);
 // read the value on analog input
pLcd.setCursor(0,0);
pLcd.print ("Vin:");
vin = analogRead(analoginput)*5.00/1024*2;
pLcd.print(vin, 3);
pLcd.print ("v");
pLcd.setCursor(0,1);
pLcd.print ("R:");
vin1 = analogRead(analoginput1)*5.00/1024;
pLcd.print(vin1, 2);
pLcd.print ("v");
pLcd.setCursor(9,1);
pLcd.print ("O:");
vin2 = analogRead(analoginput2)*5.00/1024;
pLcd.print(vin2, 2);
pLcd.print ("v");
delay(1400);
United Kingdom
You need to replace "pLcd." by "pLcd->" everywhere, as in my original instructions.
South UK
thanks I overlooked the symbols  smiley-fat
I'm getting another compile error now on this line  pLcd->.begin(16, 2);
do i still need that in there?
United Kingdom
yes but remove the . in the middle.
South UK
Thanks, I should have checked my code properly!
Just complied, and downloaded to my arduino but I'm sad to say the problem is still the same smiley-sad
United Kingdom
OK, here is one more suggestion. Change the start of setup() to this:
pinMode(8, OUTPUT);
digitalWrite(8, LOW);
delay(5000);
delay(100);
pLcd->begin(16, 2);
i.e. set the enable pin to be an output and drive it low early on.
United Kingdom
PS - an alternative that might work even better would be to add a pulldown resistor between the EN input to the LCD and ground. What I'm trying to do is to make sure the LCD doesn't think it's receiving any commands while it powers up.
South UK
does not work mate.
I'm just going to try the hardware solution now (pull down)
Thanks for the help
United Kingdom
1. Can you confirm that the LCD doesn't work after power up, but always works if you then press the reset button?
2. Confirm you have the LCD RW pin connected to Vcc?
3. If the answer to both the above is yes and the pulldown on EN doesn't work, it might be worth trying:
- a pulldown on the RS pin as well
- sending 2 begin() calls in setup() instead of just one, with a large delay between them
South UK
1- Indeed, that is the behaviour that I'm currently dealing with.
2- Pin 5 (r/w) is tied to gnd, as per this tutorial that I followed?.. http://www.ladyada.net/learn/lcd/charlcd.html
I tried a 100k to gnd on the E pin but still the same, also just tried two begin calls with a 1 sec delay in between, also no good smiley-sad
United Kingdom
Very strange. The Arduino reset line does not go to the LCD, therefore what's resetting the LCD after you press reset must be the begin() call in the LCD constructor and/or the begin() call in setup(). So the question is, what else are you doing in your sketch that is making those calls work?
I'm running out of ideas, but maybe it is some other command you sent the LCD before you pressed reset, like printing characters or setting the cursor location. So all I can suggest now is that in between making those 2 begin calls in setup, you try try doing those things.
Yes, RW to Gnd is correct, not Vcc.
« Last Edit: September 06, 2011, 12:16:16 pm by dc42 » Logged
Pages: 1 [2] 3 4   Go Up
