Topic: Speed sensor (Read 8900 times) previous topic - next topic
sweeduino
I want to measure the speed of cars passing by the street where I live. My idea was to have two laser beams that reflects on a small reflex in the middle of the road and then points to two light dependant resistors. I tested my idea on a breadboard to see if it works, and it did. But now I'm thinking that if i scale it up the smallest vibration will make the lasers miss and thereby fool the Arduino that a car has passed.
Any better ideas for a speed sensor? My idea would cost me well under 10$ so price is also a part in this.
mowcius
#1
Nov 21, 2009, 10:07 pm Last Edit: Nov 22, 2009, 11:32 am by mowcius Reason: 1
If you have access to the other side of the street then you could use lasers, it is highly unikely that the ground is going to move enought to make the lasers miss... Unless you have a lot of earthquakes :D
Mowcius
sweeduino
Maybee you're right. I'll try it. The thing is then that with that idea I need power on booth sides of the street and if two cars pass at the same time in both directions the reading will be off. But at the same time I can read the speed in both lanes, thats good. And maybee that two cars pass at the same time is unlikely. I'll give it a go.
/Ulf
mowcius
Yes, trying it would be the best option... If you are using laser beams, make sure that they are low enough so as not to put off any drivers (unless they are infa-red, would be a good option). Also pointing laser beams across the street may not be very legal... Just keep it hush hush!
Mowcius
jezuz
I would try a narrow beam US sensor pair, this model would probably be best... your accuracy will still be off though...
http://www.maxbotix.com/MB1240__XL-MaxSonar-EZ4.html
You should look around their various products (listed on left side), each has its own range in terms of distance and width of measuring "cone"... You would want one that measures far enough to reach the side of a car, but with a width small enough to be accurate when determining if a car has come in front of it and when the car has moved past the sensor...
mowcius
#5
Nov 22, 2009, 07:37 pm Last Edit: Nov 22, 2009, 07:39 pm by mowcius Reason: 1
I also just thought about using those. As you say though, due to the cone sensing, they are not very accurate for beam sensing.
Presumably you could account for a bit of that though, if it was from one to the next then presumably the cone sensing is the same so unless the car moves significantly closer or further away it would be pretty accurate...
Would cost considerably more than $10 though, $100 ish for the new maxbotix sensors?
Mowcius
jezuz
And your idea would probably just not work, sorry to say. Too many environmental factors which would mess with your setup, as you mentioned... Your best bet is either an IR or US sensor setup... I prefer US, but others may disagree.
mowcius
Yes, my idea is better for small scale. I am using lasers and LDRs on a current project of mine...
US is good but often not an option due to the costs involved, the OP obviously is concerned with that. Is there another solution that we can think of then?  ;)
Mowcius
jezuz
#8
Nov 22, 2009, 09:31 pm Last Edit: Nov 22, 2009, 09:32 pm by jezuz Reason: 1
Well, he could always rob a bank...
Well, what could be more stable is if you set up a laser on one side of the road - one of those small lasers would do, just has to be powerful enough...
on the other side you place a solar panel (one of those small ones, a few inches wide/long) inside of a case with an opening (so that the only light that can reach the panel is if the laser is aimed at it)... make sure both setups are stable and wont move when a car moves by (vibration is ok, as the solar panel should be large enough to catch the laser if it shifts a few millimeters)... and that's basically it... make two setups like that, then you basically have yourself a timegate system
mowcius
Yeah but there is still the issue of:
Lasers shining across road where people are driving = illegal?
Mowcius
jezuz
Not if it's low enough on the ground to be below the windshield level, just low enough to hit the body (as in, just above the bottom of the car's body), then there is no way that would interfere with the driver... plus, the laser's ray would be invisible to anyone driving by unless it directly hits them in the eye (which it won't), so no one would probably notice the fact that their speed is being checked unless they take the time to mess around with the four suspicious boxes placed beside the road (you should disguise them as mailboxes  ;D)
sweeduino
Nice to see your dialogue on my case.
I've looked at the sensors from Maxbotix earlier and ruled them out on count of the price. Nice to see that we think the same way. This is just supposed to be a cheap simple project in my spare time.
Lasers legal or not don't bother me that much so I'll go with that option, but then the issue still is the small light resistor. The solar panel should be a much better idea then. The time gate system is what I'm aiming for, just didn't knew the name for it.
Any hints for a suitable solar panel and how that would work?
mowcius
Not if it's low enough on the ground to be below the windshield level, just low enough to hit the body (as in, just above the bottom of the car's body), then there is no way that would interfere with the driver... plus, the laser's ray would be invisible to anyone driving by unless it directly hits them in the eye (which it won't), so no one would probably notice the fact that their speed is being checked unless they take the time to mess around with the four suspicious boxes placed beside the road (you should disguise them as mailboxes )
It still may not be legal, use infa-red ones if you can, then you wouldn't see anything (they are more expensive though).
Low enough to the ground = blind dogs?
Mowcius
mowcius
I wouldn't have thought that a solar panel would work, I don't know how you'd interface with it, a small dot on it wouldn't produce much current...
You can get larger LDRs:
http://www.rapidonline.com/Electronic-Components/Optoelectronics/Photodetectors/Light-dependent-resistor-NORPS12/34793/kw/LDR
About 10mm sensing dia. I am using them for my project...
Mowcius
jezuz
#14
Nov 22, 2009, 11:13 pm Last Edit: Nov 22, 2009, 11:13 pm by jezuz Reason: 1
http://www.youtube.com/watch?v=HKRPfa66_po&feature=fvw
You can indeed use a solar panel... don't forget to enclose it though!
and to be safe, as I mentioned, use one of about a few inches wide
